20 Most Recent
FUJIFILM FinePix AX200 Digital Camera Questions & Answers
Ax200 usb not recognized
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as
Picasa.
Got new computer, need cd
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
I have a fujifilm finepix
The date and time are stored with every image. Any photo editing program should be able to show you that data (and a LOT more); look for something like "image info" or "EXIF data". If you want the data printed with the picture, refer to the documentation for whatever program you're using to print. Depending on the program and the printer, you may be able to display the date and time on the image, in the margins, or on the back.
Need to activate date/time stamp
In playback mode, press DISP/BACK to select a playback display format. This will turn the Information display on, which will show you the date/time the picture was taken.
This camera does not have a Time/Date Stamp that actually stays on the picture like some cameras do. Instead, the Time/Date Stamp is included in the Image File Properties, and can be viewed or modified from any Windows PC. I’m happy to help further over the phone at
https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
My computer wont regiser the
Try a new cable or usb port on your computer. Remember to have the camera powered on. Also, try this with the computer off, then turn on with the camera on and plugged in.
