20 Most Recent Nikon COOLPIX P100 Digital Camera Questions & Answers
When a camera formats a card it wants control of that card. It something else changes the card the first camera will think the card is corrupted and in a way it has. Cards are not that expensive. Please use one card in one camera and back up you files on a computer.. I have found NO problem with deleting folders on my cameras using the computer. You typically can REMOVE photos on a COMPUTER you should ONLY let the camera ADD photos. use one Card for one camera.
Nikon COOLPIX... | Answered on May 12, 2018
The lens doesn't align with the sensor any longer. The body is bent, so I think a repair is impossible.
Nikon COOLPIX... | Answered on Nov 29, 2017
GT Recovery for Windows Download: www.gtrecovery.net
GT Recovery for Windows is a professional data recovery for PC and Android phones. It can restore deleted photos, videos, audios, documents from PC.
Whenever you lost important photos or deleted photos by accident, you can use it to scan and recover the photos on your phone.
Nikon COOLPIX... | Answered on Oct 17, 2017
In General. Nikon Coolpix cameras TURN ON when you change them. This means when you plug in USB with a computer the camera turns on and the computer sees it.
If you turn the camera ON. And the Battery indicator shows "FULL CHARGE" you may NOT be able to charge it.
To eliminate variables. Do not charge with the computer until you charge with the adapter (wall charger). When the wall charger works then try the computer.
Look at page 145 in your manual for Computer charging.
Make sure your date and time are set in the camera.
Make sure it NEEDS a charge.
Nikon COOLPIX... | Answered on Sep 17, 2017
Your battery is most likely dead, you will need to purchase a new one. Here is a link for one to buy on Ebay.
http://www.ebay.com/itm/EN-EL5-ENEL5-Battery-Nikon-CoolPix-P100-P90-P80-S10-/170691083898?pt=Batteries_Chargers&hash=item27bdfb3e7a
Nikon COOLPIX... | Answered on Aug 11, 2016
You don't. There are special tools and a lot of training required to do anything inside a modern digital camera. It is densely filled with flat wire cables, tiny screws and parts that will fill a drinking glass. If you do take it apart, you'll never get it back together. What do you expect to accomplish?
Nikon COOLPIX... | Answered on Jan 24, 2015
Try NOT connecting your camera to your computer.
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo management program such as Picasa.
Organize edit and share your photos
Nikon COOLPIX... | Answered on Nov 20, 2014
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nikon COOLPIX... | Answered on Oct 06, 2014
The ML-L3 does not work with the P100 camera.
Nikon COOLPIX... | Answered on Sep 12, 2014
Let's start with your battery. It could be bad, the camera's charging circuit could have failed or the electrical contacts on the battery or in the camera could be dirty.
Start by cleaning the contacts. I find that a clean pencil eraser works quite well. If that does not work, consider the age of your battery. Rechargeable batteries do not last forever. They are rated for a certain number of charge/discharge cycles and they may or may not meet the specification. Your battery could be old and cannot hold a charge; in which case you need to buy a new EN-EL5 battery.
The other possibility is that the charger circuit in your camera is not longer functional. If it has gone bad, the cost of repair might not be justified. Instead, I would buy an external charger. The Nikon battery charger you need is model MH-61. Nikon's price is $27.95, but you can probibly find one for less.
Nikon COOLPIX... | Answered on Aug 31, 2014
Quite normal the computer is saying its full or sometimes you have to turn computer off plug in camera turn it on then turn on laptop
so it will read.
Nikon COOLPIX... | Answered on Aug 18, 2014
I the file is on your computer, it means your folder is empty and there are no images or other files in it. If it says "no Image" on your camera, it simply means you have a blank memory card, or possibly "no" memory card in the camera.
Nikon COOLPIX... | Answered on Jul 02, 2014
Did you charge the battery correct? Was the power light on the camera blinking while charging? Did it take about or less than 3 and a half hour tho charge? Please also check if all contacts o the battery and in the camera are clean and shiny. To clean the contacts, only use dry cloth and / or cotton swabs. Also make sure the battery-chamber/ memory card slot cover is closed correct. There is a switch detecting an open door. As long as the door is open the camera won't start.
Nikon COOLPIX... | Answered on Jun 24, 2014
Nikon COOLPIX P100 Digital Camera Logo
194 questions posted
Top Nikon Cameras Experts
Ric Donato
pictureman4u
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
COOLPIX Nikon
  • COOLPIX Nikon
Most Popular Question
delete all pictures disk instead
  • Cameras
