20 Most Recent Bissell 25A3 Upright Vacuum Questions & Answers
Why carpet cleaner not dispursing water
Check your user's guide for troubleshooting. You may have a clogged filter. Bissell Consumer care 4-800-237-7691
1/30/2016 4:37:04 AM • Bissell 25A3... • Answered on Jan 30, 2016
My bissel pro heat has no suction
2/22/2013 8:56:52 AM • Bissell 25A3... • Answered on Feb 22, 2013
Want spray water
Hey, sorry to hear you having problems with the spray on your ProHeat. Here's a quick link to troubleshooting.http://www.bissell.com/FAQDetail.aspx?id=1065&cid=ccsocial
12/21/2012 6:16:16 PM • Bissell 25A3... • Answered on Dec 21, 2012
Bissell rug cleaner 25a3 will
If the pump is engaging, then there may be a kink in the waterline. Follow the path from the supply tank to the sprayer. If that checks out, then there may be a clog. A small piece of debris in the supply tank can end up clogging the nozzle of the sprayer. If your nozzle is removable, that is easy to check and clear up. If it is not, then you have to get a bit more creative. Using a small enough diameter rubber hose and a bicycle pump, you can blow out most debris. Cut the rubber hose to about 1 foot in length. Attache one end to the nozzle ( this may take some doing) and the other to the bike pump. With the supply tank empty start to pump. You should have a modest amount of resistance. If it says "no", then you definitely have a clog. There is really nothing to break so applying more effort to the pump should break loose whatever particles are in the line. Good luck!
6/10/2011 5:42:16 AM • Bissell 25A3... • Answered on Jun 10, 2011
Does the bissell pro heat have one or two belts?
The Bissell Model 25A3 has two belts, a pump belt and a brush roll belt. The pump belt (Bissell Part # B2150628) is flat and runs from the motor to the pump. The brush roll belt (Bissell part # B0560621) is cogged and runs from the pump to the brush roll. See key numbers 34 and 36 below.
5/17/2010 10:01:12 PM • Bissell 25A3... • Answered on May 17, 2010
When I am cleaning carpet, the water spray works
I have a Proheat 2X and had the same problem. I don't know if this will work with your unit... but I tried the Water Rinse setting and found water came out and was suctioned properly, but on the Light Clean, Normal Clean, and Heavy Traffic settings, the unit failed to do anything. Problem may be with leaving the soap dispenser in-place, which might scum up the tubing.
SO, an alternative to throwing out my unit and buying something else was to put one capful of the Bissell soap in the water resevoir and keep the unit on Water Rinse. IT WORKS BEAUTIFULLY NOW. Don't know if this will help, but at least I didn't have to buy a new unit. Rinse everything after using and there's been no problem.
4/24/2010 8:38:33 PM • Bissell 25A3... • Answered on Apr 24, 2010
Bissell spun scrub won't dispense water. Unplugged and plugged back in, press x valve, etc etc model 20391
Here are some troubleshooting steps you can try: Check the clean water tank: Ensure that the clean water tank is not empty and is filled with warm tap water and the appropriate Bissell solution. The cap of the clean water tank should be properly closed. Re-seat the water tank: Remove the clean water tank from the machine and then re-seat it back into the machine. Check for clogs: There could be clogs in the system that are preventing the water from dispensing. Check the pump motor: If the above steps don't work, there could be a more technical problem like a malfunctioning pump motor. If these steps do not resolve the issue, it may be best to contact Bissell customer service or a professional for further assistance. Bissell Carpet Cleaner Not Dispensing Water [SOLVED] (vacuupedia.net)
3/31/2024 7:28:01 PM • Bissell Vacuums • Answered on Mar 31, 2024
Bissell Spotlifter 1715. What's the output voltage & amperage of the charger for Bissell Spotlifter 1715?
No one says the output voltage and amperage, you just buy them for the Bex Bissell unit. They are dual voltage in 110 to 220. If you have the old one, it will be written in tiny writing on the charger, usually white writing on the face and engraved on the inner surface where the pins are. There are a number in the link from Walmart, eBay and Amazon. https://www.google.com/search?q=bissell+spotlifter+1715+charger+replacement ..
2/7/2024 3:04:55 AM • Bissell Vacuums • Answered on Feb 07, 2024
My Bissell little green machine has no suction at the hose end.
If your Bissell Little Green Machine has no suction at the hose end but good suction underneath the dirty water tank, try these steps: check for clogs in the hose and attachment, ensure the tank and filters are properly seated, test without an attachment, inspect for damaged hoses or seals, clean the machine, and run hot water through the hose. If the issue persists, contact Bissell customer support for assistance or consult your user manual for specific troubleshooting steps.
10/29/2023 5:07:03 AM • Bissell Vacuums • Answered on Oct 29, 2023
Fuse for a Bissell Pro heat 2X 9200E
As per wiring diagram on Page 20 of service manual, there is no fuse. Microsoft Word - ProHeat2XServiceGuide Revision 2-2-10.doc (evacuumstore.com)
10/24/2023 2:51:31 PM • Bissell Vacuums • Answered on Oct 24, 2023
ProHeat 2X Deep Cleaning System | 9200-2. How do you test the solenoid?
Remove the hoses to it and attach a piece of clean PVC pipe. With the power off, blow down the hose The solenoid should be closed. Plug the machine in and press the button for water. You should now be able to blow through it, if it is operating correctly. https://www.google.com/search?q=bissell+proheat+2x+9200-2+test+solenoid+valve ..
6/15/2023 3:30:25 PM • Bissell Vacuums • Answered on Jun 15, 2023
Bissell pro 2x healthy home carpet shampooer wheel not spinning
Hello Jeanette The answer from 'Rushikesh' that you thanked is from an Indian Artificial Intelligence Answer Bot. The site has been plagued with them for a month or so. They all answer in the same format 1. Repeat the Question. 2. Give five GUESSES to fix. 3. Tell you to consult a professional! From a real person : You need to change the drive belt, simple as that! If you turn the machine over an turn it on, if you carefully put your hand of the brushes, you will find you can stop thee brush from spinning. That shouldn't happen. ..
5/8/2023 4:06:00 PM • Bissell Vacuums • Answered on May 08, 2023
BISSELL powerforce helix silver piece fell out? 2191 not compact
It sounds like the small silver piece that fell out of your BISSELL Powerforce Helix may be the motor brush. The motor brush is a small, spring-loaded carbon block that makes contact with the motor to conduct electricity. If the motor brush falls out or is not installed correctly, it can cause the motor to make a loud, high-pitched noise. To fix the problem, you should locate the motor brush and try to reinstall it. The motor brush is typically located near the motor on one or both sides of the vacuum. You may need to consult the user manual or contact BISSELL customer service for specific instructions on how to access and install the motor brush. If the motor brush is damaged or missing, you may need to purchase a replacement motor brush from BISSELL or a vacuum repair shop. Once you have replaced the motor brush, the high-pitched noise should go away and the vacuum should operate normally.
2/15/2023 7:45:37 AM • Bissell Vacuums • Answered on Feb 15, 2023
How do I replace the upright locking foot pedal on my Bissell 3760-4
Replacing the upright locking foot pedal on a Bissell 3760-4 is a fairly straightforward process. Here are the steps you can follow:
  1. Turn off and unplug the vacuum cleaner.
  2. Lay the vacuum cleaner on its side so that you can access the bottom of the machine.
  3. Locate the locking foot pedal and use a screwdriver to remove the screws that hold it in place.
  4. Once the screws are removed, gently pull the old locking foot pedal away from the vacuum cleaner.
  5. Take the replacement locking foot pedal and position it in the same spot where the old one was removed.
  6. Use the screwdriver to attach the replacement locking foot pedal with the screws you removed earlier.
  7. Test the new locking foot pedal to make sure it works properly and holds the vacuum cleaner in the upright position.
  8. Once you are satisfied with the new locking foot pedal, flip the vacuum cleaner back over to its normal upright position.
  9. Plug in the vacuum cleaner and turn it on to make sure everything is functioning properly.
With these steps, you should be able to successfully replace the upright locking foot pedal on your Bissell 3760-4.
2/15/2023 6:08:04 AM • Bissell Vacuums • Answered on Feb 15, 2023
Bissell 25A3 Upright Vacuum Logo
21 questions posted
Top Bissell Vacuums Experts
Mike Cairns
Mike Cairns
Renee Knafel-Bullock
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Bissell Vacuums
  • Bissell Vacuums
Most Popular Question
  • Vacuums
