20 Most Recent RCA RP5022 Digital Voice Recorder Questions & Answers
  1. Turn on the player.
  2. Press Erase, Delete will flash on the display.
  3. Press and hold Record for three seconds. Format will flash on the display.
  4. Press and hold Erase. Wait will show on the display, formatting is in progress.
  5. After the formatting is complete, the remain time of the selected memory will show on the display.
This will format your voice recorder and delete everything on it.
RCA RP5022... | Answered on Jan 19, 2018
I'm pretty sure if you formatted it, it erased all of your recordings and you won't be able to get them back. That's for about anything you own and reformat it....digital camera sd card, hard drive on video camera...etc
RCA RP5022... | Answered on Feb 11, 2013
Press and hold MENU for three seconds.
RCA RP5022... | Answered on Jan 31, 2012
Press and hold [MENU] for three seconds.
You may view the manual here.
GET MANUAL AT WWW.RCA.COM ... UNDER AUDIO / VIDEO LINK.
RCA RP5022... | Answered on Feb 19, 2011
Sounds like you've lost the user manual...go to www.rca.com ...manuals and downloads are in the Audio/Video link.
RCA RP5022... | Answered on Feb 14, 2011
Iin this case, You can solve this problem by running "Error Checking" on your computer. You Go To: "My Computer" and find your RP5022 Drive Listed there. "Right Click" on it and Go To "Properties"...Once Open Click On "Tools" and Look for the Window that says "Error Checking". Click On "Check Now" when it Opens (Be Sure) to (Check the 2 Boxes) Listed. Let it run the Error Check...AND RESTART YOUR COMPUTER WHEN FINISHED.hope this helps.
RCA RP5022... | Answered on Jan 04, 2011
Hi
Please click on below link to view/downloadf the user manual for RCA RP5022
RCA RP5022B User manual
Hope this helps...
Daniel
RCA RP5022... | Answered on Oct 09, 2010
the files on your voice recorder is actually corrupted just as the computer is indicating.
I don't know how important these files are to you but I'm afraid you might loose them because they are corrupt.
To fix this problem, you need to format the recorder and by so doing you will loose all your files but the recorder will be okay. You will have to put fresh files on the recorder.
Your computer may have been the one that corrupted the files on your recorder.
To format the recorder, while the recorder is connected to your computer, click start menu, go to computer. You will see a drive representing your recorder, right click on the drive, scroll to format and click it. This will format your drive and your recorder will be fixed.
Note, that you will loose all the files on your recorder in the process of formatting.
Good luck.
RCA RP5022... | Answered on Sep 24, 2010
I turned my recorder on one day and only had 20 min of recording time and it was nothing on it took me awhile but i figured it out you have to put it on your pc and reformat it when i did that i got back my 26 hrs of recording time hope that helps
RCA RP5022... | Answered on Aug 02, 2010
Stereo amplifies are just two mono ones joined together. So if you have a problem with the left you can always look at the right side if that is working good. As all the parts are the same and so are any voltage readings taken. A visual inspection is the first option, if something looks strange in the left channel compared to the right, then replace it with the same part you can see in the right. The only problem is when the amp uses one power amp for both channels. But in that case replace the thing.
Apart from that individual parts, such as the power supply, you can leave alone, as they would affect both channels.
RCA Audio... | Answered on May 09, 2019
Hello Melissa, if the predefined channels, you can not find them, because they have been deleted, you can retune them and memorize them, then you have the way to do it
Choosing A Radio Station
1. Choose the Tuner function. The system will default to the last station of the tuner was set to before power was
removed.
2. Use the BAND button to choose AM, FM 1 or 2.
3. Use the TUNING UP (+) or DOWN (-) button to select the radio station you want to hear.
• Pressing the +/- button once will move the tuner incrementally.
• Pressing and holding the +/- button will cause the tuner to automatically search for the next frequency
broadcasting clearly. "AUTO" will appear in the display.
4. Press the FM MODE button to switch between FM Stereo and FM Mono for better reception of FM stations. Be
aware, however, that you can only receive FM stations in stereo if they are being broadcast in stereo.
Programming presets
Your system is capable of holding up to 24 preset radio stations in memory (8 from FM1, 8 from FM 2 and 8 from AM)
for as long as the unit is plugged in, and up to two weeks after AC power has been removed.
1. Choose the radio station and band you want to store.
2. Press the MEMORY button to activate the Preset mode.
3. Select a preset number by using the PRESET UP () or DOWN () buttons to select the preset channel you want
to hear.
4. Press MEMORY again to lock in your choice.
After you have finished programming your selections into the system's memory, you need only use the PRESET UP or
DOWN buttons on the unit to search for the desired frequency. On the remote, use the number pad to select the
number of the preset channel you want to hear.
I hope my comment has served you
Greetings Franco Dosil
Hola Melissa, si los canales predefinidos, no puedes encontrarlos, porque se han borrado, puedes resintonizarlos y memorizarlos, a continuaci?n tenes la forma para hacerlo
Elegir una estaci?n de radio
1. Elija la funci?n de sintonizador. El sistema pasar? por defecto a la ?ltima estaci?n en la que se ajust? el sintonizador antes de que se
remoto.
2. Use el bot?n BAND para elegir AM, FM 1 o 2.
3. Use el bot?n TUNING UP (+) o DOWN (-) para seleccionar la estaci?n de radio que desea escuchar.
• Presionando el bot?n +/- una vez mover? el sintonizador de manera incremental.
• Si presiona y mantiene presionado el bot?n +/-, el sintonizador buscar? autom?ticamente la siguiente frecuencia
transmitiendo claramente. "AUTO" aparecer? en la pantalla.
4. Presione el bot?n FM MODE para cambiar entre FM Est?reo y FM Mono para una mejor recepci?n de las estaciones de FM. Ser
Sin embargo, tenga en cuenta que solo puede recibir emisoras de FM en est?reo si se emiten en est?reo.
Programaci?n de presets
Su sistema es capaz de almacenar hasta 24 estaciones de radio preestablecidas en la memoria (8 de FM1, 8 de FM 2 y 8 de AM)
durante el tiempo que la unidad est? enchufada, y hasta dos semanas despu?s de que se haya desconectado la alimentaci?n de CA.
1. Elija la estaci?n de radio y la banda que desea almacenar.
2. Presione el bot?n MEMORY para activar el modo Preset.
3. Seleccione un n?mero de presinton?a usando los botones PRESET UP () o DOWN () para seleccionar el canal de preset que desea escuchar.
4. Presione MEMORY nuevamente para bloquear su elecci?n.
Una vez que haya terminado de programar sus selecciones en la memoria del sistema, solo necesita usar PRESET UP o
Los botones ABAJO en la unidad para buscar la frecuencia deseada. En el control remoto, use el teclado num?rico para seleccionar el
N?mero del canal preajustado que desea escuchar.
Espero te haya servido mi comentario
Saludos Franco Dosil
RCA Audio... | Answered on May 06, 2019
RCA RP5022 Digital Voice Recorder Logo
Popular Tags
20 questions posted
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Audio Players & Recorders
Most Popular Question
need manual rca rp5022b
  • Audio Players & Recorders
