20 Most Recent
LaCie 500GB RUGGED USB 5400 RPM 8MB 500 GB USB 20 Hard Drive Questions & Answers
I was transfering files from my HD. I transfered
MMMM...Simply transferring files shouldn't do anything to damage the drive or cause it not to appear in windows anymore. It sounds like perhaps that drive may have had some vendor software in it and perhaps that program isn't running anymore so you aren't seeing that?
Try turning the drive off and then wait about 30 seconds and turn it back on and see if it appears again. If it doesnt come up like you are used to seeing it go to start> my computer and see if you see it in the list of drives there as it should show up.
I think you are used to seeing a program run and now that it isn't perhaps you think it isn't there when it really may still be there.
If this was a help please give me 4 thumbs up as I am trying to build up my rep on this site!
I need to know how to do a factory reset on a lacie 4Big Quadra enterprise.
- Disconnect all cables from the device.
- Press and hold the "reset" button (located on the rear panel) for about 10 seconds.
- Wait for the device to restart and initialize. This may take several minutes.
- Reconnect the cables to the device and try accessing it again.
Note: It's recommended to backup all data stored on the device before performing a factory reset, as all data will be lost during the reset process.
My LaCie external drive isn't getting power
U should test for power at the connector that goes into the lacie with a voltmeter to make sure power supply and its wire are OK. If no voltmeter then use a automobile brake or turn signal bulb to see if it has power.
Lacie n2870 driver
You need a new driver for sure, and here you can find it
driverupdate us. This tool usually keep my drivers up to date (perfectly for now)
take a look
