20 Most Recent
Verbatim 96823 320 GB USB Portable (Blue) Hard Drive Questions & Answers
My portable hard drive wont connect to my
hi there,
While the Hard drive is connected to one of the USB ports on your computer.
On your keyboard press and hold the power button and press the letter R.
When the Run box comes up type in devmgmt.msc
Expand the Universal Serial Bus cotnrollers
right click on every root hub and choose uninstall
after that restart the computer
Hope this helps!
I have a verbatim 320GB
From the information provided, it appears to be a direct hardware failure. Verbatim appears to not offer much on providing information on such issues, so it would be safe to say is have it replaced.. I am not 100% sure but some external drives come with a 7 year warranty, you could also try to have your data recovered from a local computer service in your area so you do not lose the data. But, in all it would be advised to replace it.
I've plugged a portable harddrive in and it's not
The USB memory key want to use a drive letter already in use. To fix it ,click on start,right click on My Computer then click on Manage. You may need to enter your password or click on Continue in the User Account window. Click on Disk Management and look for an entry that does not have a drive letter. Right click on the drive and then click on Change Drive Letter and Paths. Click on the Change button and select a new drive letter from the dropdown menu.Click OK in both windows to save.
Regards Bill
About License under software manager
I would ask a lawyer who is well versed in copyright law if you wish to change a public OS.
Why not download the beta and that can be adjusted and returned for evaluation.
2/7/2024 8:54:41 PM •
Verbatim...
Answered
on Feb 07, 2024
My Verbatim External hard drive Model 47672 just won't power up all of a sudden. How do I go around fixing it, using, etc?
The device is USB powered and the first test is to see if it opens on another computer and if not, another cable. If it does not work, the next thing to know is the probability of being able to get the unit operating again is very slim. Those devices use SMT components and they require very specialized service and diagnostic equipment. That is the reason that these drives come with back up software. You need to back up the back up. There is a slight chance that you may be able to remove the drive from the housing and plug it into a computer directly, of use a universal cable to activate it. Keep in mind that the drive has a lifespan.
4/20/2020 12:48:34 AM •
Verbatim...
Answered
on Apr 20, 2020
Dvd player keeps saying wrong region code
You only get to make four or five code changes and, for copyright reasons, thats it.
You can download Anydvd from Slysoft.com and it will nest in your desk top, and remove all dvd codes as you load. The dvds then run "Region Free"
They will copy with Dvd shrink and so your back ups are region free as well.
2/13/2020 2:23:24 PM •
Verbatim...
Answered
on Feb 13, 2020
Verbatim USB1T external drive
Assuming it’s powered on, do you hear the “usb” sound when you connect it to the computer? If not, try a different usb port, or a different cable. If you hear the sound, check for the disk in “computer management”. It may need partitioned or formatted.
3/27/2019 3:10:09 AM •
Verbatim...
Answered
on Mar 27, 2019
