20 Most Recent Gateway NV7802U Notebook Questions & Answers
START AT THE LINK BELOW... another user has the SAME error code as you... he followed the instructions and his system is WORKING again!
Anthony
Windows 7 help and support forum
Gateway NV7802U... | Answered on Dec 16, 2017
Can you pls elaborate a bit. What machine, what platform, what application, etc etc.
Gateway NV7802U... | Answered on Nov 03, 2013
Regret to tell you that this may be due to multiple circuit damages as the motherboard is located rite underneath the keyboard. I suggest you not to try starting-up the laptop as this may cause further damage. Take it to a hardware shop and they would be able to diagnose the problem precisely.
Gateway NV7802U... | Answered on Sep 19, 2013
Dear user,
Please also try Fn+ F7, or the key that has a box with a hand on it. hold it for some time each time you try
Gateway NV7802U... | Answered on May 04, 2013
Have you tried holding the power button down until it shuts down completely, then unplug the AC adapter, remove the battery, put it all back together then try powering back up?
Gateway NV7802U... | Answered on Mar 27, 2013
harddrive issues
Gateway NV7802U... | Answered on Feb 24, 2013
Find a tear down guide for your laptop. You'll want to get to the connection beneath the keyboard and see if the connection can be reseated. This will probably fix the problem. It could also be damaged, in which case you'll need a replacement.
Gateway NV7802U... | Answered on Nov 14, 2012
One trick I always use is going to start>run>type msconfig> startup menu. remove as much as possible here of items you don't need to run at startup. this will speed your machine up.
Gateway NV7802U... | Answered on Oct 11, 2012
Check BIOS if all RAM is being picked and or set to max on RAM settings.
Upgrading BIOS! If it isn't broken don't fix it. Upgrading is a scapegoat fix, and many manufactures have a disclaimer. "You are on you own, and the likes for a reason. Most solutions are found elsewhere.
However, if you truly need to update read this to help you with the upgrade.
http://www.techrepublic.com/blog/10things/10-common-mistakes-you-should-avoid-when-flashing-your-bios/357
GL
PS. Many applications are written for 32 bit, hence they are unable to fully utilize 64 bit and may be bound to 4GB.
Gateway NV7802U... | Answered on Oct 10, 2012
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Gateway NV7802U... | Answered on Aug 20, 2012
You need to find out why your laptop is overheating, usual suspect is dust, make sure that your heatsink ribs and the fan are clear from dust, could also be worth putting new heatsink paste on the processor and graphics chip
Gateway NV7802U... | Answered on Jul 09, 2012
take it to a professional for inspection, there are too many possibilities for me to guess over the internet, needs to be looked at in person.
Gateway NV7802U... | Answered on Jul 01, 2012
Remove main battery and try again, next! sub out one ram stick at a time testing as you go, if still no result! check power adapter for correct voltage, if okay! the motherboard needs to be assessed.
Gateway NV7802U... | Answered on Mar 20, 2012
Most laptop keyboard are secured by screws on the bottom of the laptop. The screws that fix the keyboard may have a tiny heyboard symbol against the screw.
When you remove the keyboard screws you can then lift the keyboard off the laptop. The keyboard is connected to the motherboard via a flat ribbon cable, it may have a connector on the cable or a locking clip on the motherboard. Release this ribbom cable from the motherboard, don't pull on this cable or you may damage the ribbon cable.
Keyboard replacement, LCD screens for mobile phones, Ipodsand computer equipment are available from this WEB site.http://www.yallstore.com/index.php?main_page=advanced_search_result&search_in_description=1&zenid=1lrjst3ncshlb4c7frn9bev3c3&keyword=keyboards.
Gateway NV7802U... | Answered on Mar 02, 2012
Welcome to Fixya. Would like to know if you are referring to a DVD movie or all DVD CD? Please provide the information needed so that we will be able to fix the issue.
If this is an issue with a DVD Movie then all you need to do is to download and install a codec pack. The link is provided below.
Klite Mega Codec Pack Download
If this is an issue with all DVD please let me know. Thanks
Gateway NV7802U... | Answered on May 11, 2011
Check and see if the hard drive came loose check the bios to see if it is recognized..It is saying there is nothing with an O/S on it and when you put the disk in it does not register a hard drive to restore..Check the hard drive and start the computer up and see if you can cancel the restore and start the laptop up regular..
Gateway NV7802U... | Answered on Mar 28, 2011
Hi aprilbonham,
I recommend contacting your computer manufacturer and ask assistance with their technical support. Ask if they could repair the system even you accidentally dropped the computer. Most of physical damage voids out the warranty so you need to contact them to check if your system is still in warranty and can cover induced damage.
Hope it helps.
Thanks for using FixYa
Best regards,
Reyjoshua07
Gateway NV7802U... | Answered on Jan 18, 2011
get rid of the dog, then take laptop to a good IT repair shop & they can sorted!
Gateway NV7802U... | Answered on Dec 31, 2010
The fan may be running too slow (faulty bearing) or the fan and heat sink assembly may be clogged with dust.
Check the CPU fan to see if it spinsfreely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Gateway NV7802U... | Answered on Dec 30, 2010
Gateway NV7802U Notebook Logo
36 questions posted
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
nv Gateway
  • nv Gateway
Most Popular Question
touchpad not working gateway laptop
  • Computers & Internet
