20 Most Recent Seiko Smart Label 240 Thermal Printer Questions & Answers
Go to the Start, Settings, Printers. Select your printer, the set it as your default printer.
You can also get to the printer by way of the Control Panel.
Seiko Smart... | Answered on Jun 04, 2018
The official Seiko site is:
Software Driver Downloads
However, Seiko has deleted its legacy printer support so you will have to find your drivers on a third party site. I've included links to your drivers below:
Seiko SLP 420 Free Driver Download
SIISLP200 Drivers Download for Windows 7 8 XP Vista
Note: With Seiko Smart Label printers make sure your printer is not connected to your computer until the Seiko software tells you to.
Important tips when finding and downloading application/ driver software from non-OEM sites
1. Never install any application from a non-OEM site that says it will scan your computer to determine what files you need. - search using the manufacturer name, model number, and current operating system on the computer you want to install the device on.
2. Only install the files you found. Never download any software suggested.
3. When installing the downloaded files, always select Custom Installation to make sure you only install the software you need. In this case only the application and driver files, nothing else ( no driver updating, security scanning, toolbar, etc. programs).
Seiko Smart... | Answered on Feb 28, 2015
If the answers above don't work check your AC adapter with a multimeter to confirm its output voltage. If the voltage is off by more than 1 volt you will need to replace your network driver
Smart label drivers (and every other driver related problem) can be easily found here: Driver Update
have a nice day
Dennis
Seiko Smart... | Answered on Jan 05, 2015
You shouldn't have to open the back of the printer. You may be having problems with the platen being too tight to allow you to load labels.
If included a picture to help describe the loading process:
Pulling the lever forward (3) releases the Platen tension. Feeding the labels from the bottom of the roll (4) into the slot shown. With the tension off the Platen you should be able to insert the label all the way through the printer
Seiko Smart... | Answered on Dec 15, 2014
I think you're out of luck. The latest driver I could find is 6.9.0.385, you can find it at the site below:
Smart Label Printer 200 420 overview Smart Label Printer 200 420 overview
This is a third party site, Seiko has removed all legacy support from their site. It was really only written for Windows Vista but people found it would work for Windows 7. Given the major structural changes in Windows 8.1 I don't think the legacy software will run in a Windows 8.1 environment
Unfortunately, this is usually an indication that the label roll in the printer are too old. This action is by design, compatible labels should have a black rectangle on the reverse side and the Smart Label printer uses the black rectangle to orient the label. This means your Smart Label doesn't think its wasting labels, it's just trying to run through what it considers to be unsuitable labels as fast as it can. If you're only printing one label at a time you can recover some labels by correctly the label's line up after each label you print but there's nothing you can do so that your printer will properly advance its current labels.
Remove the current roll, open a new boxed label roll, remove a sealed roll, cut open the sealed plastic, remove fresh label roll and load it in your Label Printer. Power the label printer back on and press the label advance button, it should correctly line up.
Seiko Smart... | Answered on Nov 21, 2014
Seiko has really downgraded its legacy product support and it has minimized its application and driver software available for download. To find software for your SLP 200 you'll have to good to a third party site like Drivers Guide. The link below is for version 7.0.3
In the specific case of the Seiko Smart Label printer make sure your printer is not hooked up until the Seiko software tells you to.
Seiko Smart Label 240 Thermal Printer Logo
30 questions posted
Top Seiko Office Equipment & Supplies Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
ray gallant
Are you a Seiko Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Label Seiko
  • Label Seiko
Most Popular Question
smart label printer 200 windows 7
  • Office Equipment & Supplies
