20 Most Recent
Sony Cybershot W330 Digital Camera Questions & Answers
I deleted pictures from my
You have chance to get those pictures back if you take care.
First things first: DO NOT take any more photos with the memory card(within your camera) that you want to recover photos from. Take the card out of your cam and put it in a safe place. Because if you take any more files or save any data to your memory card, you may quite possibly ruin your chances of recovery.
Then Connect the card to your computer as it should appear as a "Removable Drive" or put the card in a card reader attached to your PC.
Next, if you are comfortable with using a PC then you can download a photo recovery utility that will recover your pictures with this software called
Wondershare Photo Recovery (I once used this program bounded with some other software) from the following link(the program also
recover videos and music files):
Photo Recovery for Windows (if you are running
Windows OS)
Photo Recovery for Mac (for
Apple Mac OS X)
Remember - Do NOT try & write anything back to your camera(memory card) until you can recover the files safely!
Sony w330
Do you really need a driver?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo management program.
Computer does not read my sony DSC W-330
Try NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
Won't download pictures to my computer
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
Cannot find reset button
To reset your camera, remove the battery for 15 mins, replace the battery then go to the camera's MENU to set the Date & Time.
Memory card blocked
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.Memory Sticks have a slide switch on the back, near the contacts. Slide the switch away from the "LOCK" position.
Sony cybershot dsc-w330 functions buttons does not work
Remove the battery and the memory card, press and hold power for 60 seconds this should remove residual voltage and reset the processor ic, if there is no change the systems controller board has failed, cheaper to replace camera.
How to fix reinsert memory
Hello.
Remove the SD card then replace it back. If you are still having a problem, format the SD card using the camera. If that still doesn't solve the problem, you need to replace the SD card with a new one.
The camera won't connect to the computer to
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
I didn't delete any of
Sometimes the camera just has a problem. Put the memory card into your computer without taking more pictures or messing with it on your camera. The computer usually will read the file error pictures just fine.
