20 Most Recent General Electric GE J1050 Digital Camera Questions & Answers
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO A COMPUTER
If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos and to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
General Electric... | Answered on Jan 30, 2013
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
General Electric... | Answered on Dec 22, 2012
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Do you have a question about this camera? You may download a copy of the quick start guide here and the user manual here.
General Electric... | Answered on Nov 27, 2012
Look at your memory card. SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
General Electric... | Answered on Nov 02, 2012
Having gone over a month without a response to my query, I assume my suggestion to use a card reader eliminated the need for a driver.
General Electric... | Answered on Jun 25, 2011
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
General Electric... | Answered on Jan 03, 2011
http://www.general-imaging.com/uploadedFiles/40_Support/User_Manuals/X500/GE_X500_UM_Eng.pdf
General Electric... | Answered on Mar 07, 2016
What model GE camera?
General Electric... | Answered on Mar 23, 2014
The only other suggestion is check the battery and camera teminals make sure the contacts are clean, if no! the problem is more than likely in the systems control board "the brains of the camera"
General Electric... | Answered on Mar 17, 2012
quick-start guide:
http://www.general-imaging.com/uploadedFiles/40_Support/Quickstart_Guides/GE%20X500_QSG.pdf
user manual:
General Electric... | Answered on Sep 19, 2011
Since you didn't specify the model of the camera, the best I can do is to direct you to
http://www.general-imaging.com/us/support.aspx
General Electric... | Answered on Jul 15, 2011
Was there a cd with the camera? Most manufacturers put the manual on the cd.
General Electric... | Answered on Jun 28, 2011
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
General Electric... | Answered on Dec 27, 2010
General Electric GE J1050 Digital Camera Logo
8 questions posted
Top General Electric Cameras Experts
Harrie
David Hoff
Tom Chichester
Are you a General Electric Camera Expert? Answer questions, earn points and help others
View Most Popular
  • General Electric Cameras
Most Popular Question
removed write protect
  • Cameras
