20 Most Recent
Yorx DM113 Shelf System Questions & Answers
How Do You take off the turntable
The mat can be removed from the platter. Under this there are often holes through wich you can see the belt and motor. The belt should have some play in it but if it pulls away easily it probably needs replacement. Sometimes there is a C shaped clip holding the platter on. If so remove it and lift the platter. Otherwise the platter just sits on a bushing around the spindle. Lightly lift the platter and if it still doesnt come off you can LIGHTLY tap the spindle while lifting the platter and that should free the platter. If it is in one piece measure it lay it flat and measure it end to end and then double that measurement. The most common is 23.6" however there are 20.7", 25", 28" and 38.8", MCM electronics has them for a few bucks each. Simply place it on the inner ledge on the bottom of the platter and stretch over the motor pully. If the speed seems off check the placement on the bottom ledge and the pully. The belt if places d too high or low can ride up the pully to the top where its wider and make the table fast.
Remote doesn't always work. New batteries.
Some people accidently obstruct the remote sensor on the system so that the remote can't send the signal. Check that it's not obscured by anything, including the position of the unit.
If that doesn't make any difference then either the remote is playing up, or the remote sensor has a fault on it.
8track player not playing
There's no place to put a usb stick! lol It's time to replace some belts and clean the rubber rollers with rubber renue. clean the play head etc
How do I change to degree mode on my porpo YH-2000
- Power Off: Turn off the device.
- Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
- Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
- Power Off Again: Turn off the device once more.
- Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
- Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS.
Question moved from Cars and Trucks category.
Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries.
How long is the warranty on AfterShokz?
While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase.
Jan 11, 2019
https://www.google.com/search?q=Openfit+Shokz+battery+replacement
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first.
But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
