20 Most Recent Sangean RCR-1 Clock Radio Questions & Answers
Hello
The problem is mechanical> I can't give you the full details here alongwith by words. I've both its user manual and service manual. If you are interseted I'll send it to you. Send your email address to me by Fixya and let me send these to you by return mail. Service manual contains all the details of repair and faults. OK.
Sangean RCR-1... | Answered on Dec 06, 2017
Do a factory reset followed by a 5am alarm setup
Sangean RCR-1... | Answered on Aug 02, 2015
www.sangean.com/support/.../Manual
Sangean RCR-1... | Answered on Jun 28, 2014
Alarm settings can be made with clock/radio on or off.
The Alarm Clock/Radio is equipped with two independent alarm
systems each of which can activate the Human Wake System Buzzer
or turn on a preselected radio station.
Using Alarm with a Preselected Radio Station:
Select desired station using + or - Tuning Button [18] or select one
of the 1-7 presets.
Set the desired volume level using Alarm Level Adjustment [9]
Select alarm system 1 or 2 by pressing the alarm button [14] or [15].
Display will blink with selected alarm
Press alarm set button [16]
Display will blink showing selected alarm hour and alarm mode
and beep
Press alarm Mode button [20] to select alarm mode
Use + or - button [18] to set alarm time hours.
Press set button [16] to set minutes using + or - button to
set minutes.
Press alarm days selections 1-7 (Sunday-Saturday) to select
alarm days.
Display will show the days on which you wish to be awoken by the
radio alarm.
Pressing alarm button 1 or 2 will confirm settings and a beep and
display indicates radio alarm is set.
Note:
If alarm days or alarm mode are not selected display will blink
all the days for a few seconds indicating the alarm is not set
and the alarm will not be activated.
If you would like to be awoken to the station you are presently
listening to press alarm button 1 or 2 for more then 2 seconds.
This allows the station you are listening to be stored into
memory. Then follow above procedures.
Using Alarm with HWS Alarm Beep:
Display will blink with selected alarm Press alarm set button [16]
and beep
set minutes
alarm days.
buzzer humane alarm
display indicates buzzer humane alarm is set.
Note:
Cancelling Alarm Setting:
Alarm functions can be cancelled:
and beep
Press alarm Mode button [20] one or two times (depending if you
were in the alarm radio or alarm buzzer mode) till display blinks.
Press alarm 1 or 2 button again to confirm alarm cancellation.
The symbol will stay on the display for about 2 seconds
and disappear.
You may also select days you wish to be or not to be woken after
pressing the Set button while display is blinking. Press 1-7
(Sunday-Saturday) of button [19] to make a selection.
This is the figure of your device and you can find which button where is:
Thanks.
gylacz
Sangean RCR-1... | Answered on Jun 10, 2011
You can get the manual on the link below it will tell you how to reset the stations.
RCR-1-Atomic-Clock-Manual.pdf">http://igor.chudov.com/manuals/Sangean-RCR-1-Atomic-Clock-Manual.pdf
Good Luck
Sangean RCR-1... | Answered on Nov 29, 2010
Sangean RCR-1 Clock Radio Logo
Popular Tags
19 questions posted
Top Sangean Audio Players & Recorders Experts
Pete Vernall
Level 1 Expert
Sock Puppet
Are you a Sangean Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sangean Audio Players & Recorders
Most Popular Question
39 ve sangean rcr 1
  • Audio Players & Recorders
