20 Most Recent Maytag MDB6709AW Builtin Dishwasher Questions & Answers
Use the heated dry and do leave the door open a crack after each wash and you should have no issues.
Maytag MDB6709AW... | Answered on May 10, 2017
After a dishwasher is installed the hose rarely comes to mind - unless a problem occurs and a repair person comes out to inspect the job. If the hose was installed improperly, or if it is lying in a position that does not let it drain, stagnant water will create a bad smell. Examine the hose that is probably inside the kitchen cabinet beneath the sink. If the hose is lying in the bottom of the cabinet, it is probably full of water. A film begins to form inside the hose and the odor begins to grow. The next time the dishwasher is used, the stagnant water ends up on dishes, and in the meantime it can cause a bad smell inside of the dishwasher. Hang the hose at an angle on supports in the back of the cabinet. This alone might get rid of the bad smell inside the dishwasher.
Check the Seal
A dirty dishwasher seal can be a source of a bad smell. Before deciding the dishwasher needs to be replaced, check the seal - especially at the bottom. Old food and grime builds up in these areas and can cause a particularly bad smell. Clean it with a solution of diluted bleach and hot soapy water. One teaspoon of bleach for each quart of water is sufficient to kill germs and the odors they create.
NB I decided to add a little bit of vinegar to the machine after I unloaded it. Sure it would smell pretty strong for a while but then the smell would dissipate. Voila! For two weeks now my dishes have not smelled whatsoever.
Maytag MDB6709AW... | Answered on Jun 20, 2015
First step is similar to a computer. Reboot. Turn off your dishwasher at the breaker box. Hopefully your electrician designated a separate breaker for your dishwasher, otherwise whatever else is on that breaker will be off. Shut the breaker off; wait 10-15 minutes; turn breaker back on. This will resolve many issues and is the first step to try.
Maytag... | Answered on Jun 08, 2019
Shut the dishwasher off at the breaker. then restart it. See if that clears the board.you may have put the machine into a control lock out. Look for that button. press and hold it for 3 seconds. see if that doesn't clear the board.
Maytag... | Answered on May 25, 2019
all direction are on display when you close check a light comes its secure
of course after you put detergent open the fawcet water inlet
if any warm light on check the status probably you hava a damage switch door
Maytag... | Answered on May 01, 2019
Try pulling out maximum distance and then lift up at the front and then slide toward you.
Maytag... | Answered on Apr 21, 2019
Most likely the control panel is defective.
Maytag... | Answered on Apr 05, 2019
The Maytag spray arms always get clogged and stop spinning. There is no easy way to remove the food matter from the inside of the spray arm after it gets pretty filled....UNTIL NOW...Drill a 1/4" hole on each end of the spray arm on the top. This method works for either spray arm, but be careful to leave at least 1/8" of distance from the two small holes that spray out water, when you drill the hole. Then using a Dremel tapered stone grinding bit enlarge the hole to 5/16" to accommodate a stainless steel 5/16" plug with the inside hex head. Also use the fine thread, not the course thread, as it will screw more securely onto the thin stainless gage arm and will last. Grind to enlarge the hole a little at a time to make sure your plugs thread into the arm snugly. I have been using our modified arms on our Maytag for over a year and we now have consistently sparkling, clean dishes. We run the washer twice per day and clean out the arms at least once per week which takes only two or three minutes.
Maytag... | Answered on Mar 31, 2019
Look at drain lines under sink, if you have PVC put a bucket or large plastic pan under and remove all the drain lines and inspect them. Look at air gap or ensure drain line highest point is just under the bottom of counter top,. look at pump in dw to ensure is is working.
Maytag... | Answered on Mar 12, 2019
Maytag MDB6709AW Builtin Dishwasher Logo
13 questions posted
Top Maytag Dishwashers Experts
Carmen Mikulic
Mike
Marvin
Marvin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Maytag Dishwashers
  • Maytag Dishwashers
Most Popular Question
purchased maytag dishwasher
  • Dishwashers
