20 Most Recent
General Electric GDWF160RSS Stainless Steel Builtin Dishwasher Questions & Answers
Our dishwasher will not drian out all the way. I
hi Richardcr1.
After having examined many dishwashers that were replaced because they wouldn't drain
, the largest percentage of them were simply because of a clogged drain
hose or pump strainer. Too many people seem to think that the dishwasher
is first cousin to a garbage disposal. It is not
.30 Apr 2010
https://www.ifixit.com/Answers/View/.../Does+not+drain+the+water+at+the+end+of+cycl...
How do I fix my dishwasher that will not drain?Check for a clog:Make sure the kitchen sink drain is not clogged.If a disposer is installed, run the disposer to clear the drain system. Do not put hands into the garbage disposer. ...If an air gap is installed, remove the cap and remove any debris. ...Do not use drain cleaner in the dishwasher.Dishwasher Does Not Drain - Products - GE Appliancesproducts.geappliances.com/appliance/gea-support-search-content?contentId=16240Search for: How do I fix my dishwasher that will not drain?
How do I unstop my dishwasher?
Turn the breaker off for five minutes and the turn back on. Start the dishwasher and see if it will drain. Sometimes power bumps can mess with the control board. Otherwise it could be the control board or the pump.
Model 7000
Pull the inside panel off to see what is going on with thr relat that controls this. Probably ther is a leak that has caused some corrosion on this assembly.
Dishwasher troubleshooting
Remove them and check that they don't need cleaning. The top ones usually move with the power of the water going through them. If they are blocked the water can't get through and they can't turn.
