20 Most Recent Microsoft SQL Server 2008 Enterprise Full Version for PC (1 Server/s, 1 Processor/s) (810-07364) Questions & Answers
tip
How To Fix SQL Server Error 5171
This informative video shows you SQL Server Error 5171 reasons and different methods to the error
4answers
How do I recover data from .mdf file
Detach you database. Overwrite the mdf and ldf files you've restored from your backup with your files from the D: drive. Reattach the database. There is no guarantee that this will work or if it works, that your database is in a state where you can continue to work with. If that doesn't work then there is an option to try to restore database using SQL Server Recovery Toolbox. It is a powerful tool for data recovery. They have a demo version. So you can check it works in your situation or not. http://www.oemailrecovery.com/sql_repair.html
7/29/2017 6:02:36 AM • Microsoft SQL... • Answered on Jul 29, 2017
2answers
SQL 2008 R2 - MASTER.LDF corrupted without backup
Try this one solution... 1. First Shutdown SQL Server 2. Then move the current database file/rename (do not touch the .ldf) 3. After rename/move db, restart SQL Server 4. Create a new database with same name and log file and location also same 5. Stop SQL Server Make use of some interesting links which might help you.... http://www.filerepairforum.com/forum/microsoft/microsoft-aa/sql-server/1465-table-in-sql-server-2008-is-corrupted - a lot of guides and tips for corrupted sql server databases https://repairsql.recoverytoolbox.com/ Recovery Toolbox for SQL Server - free demo version of this tool, if any variant doesn't seem effective
6/7/2016 7:09:12 AM • Microsoft SQL... • Answered on Jun 07, 2016
2answers
How to do restoration of sql database?
It is possible to try also standard means to restore. .For this we need to use the RESTORE DATABASE command is executed using sqlcmd. Or there's another option. You will be able to restore also through the utility of Recovery Toolbox for SQL Server. Here https://sql.recoverytoolbox.com/
6/1/2016 8:42:19 AM • Microsoft SQL... • Answered on Jun 01, 2016
2answers
How to Change SQL Server 2005/2008 User Password
There is one SQL password recovery tool, SQL Password Genius, which would help you to successfully change SQL Server 2005/2008/2012 user password instantly, especially when you couldn't think of other ways for it. 1. Open SQL Server Configuration Management and stop SQL Server Services. 2. Install SQL Password Genius full version and run it on computer. 3. Click "Open File" button to import master.mdf database file into this recovery tool. 4. Select user in list and click "Reset" button. Instantly, new user password would be available for SQL Server logon after you type new password for user. Now, SQL Server user password has been changed and you can login into SAL server now. But please remember to restart SQL Server Services before you access to SQL Server with user password.
5/26/2016 6:14:48 AM • Microsoft SQL... • Answered on May 26, 2016
tip
Fix: Cannot Start SQL Server Service Error 3417
Know how to fix windows could not start the SQL Server (MSSQLSERVER) service on local computer error code 3417.
2answers
Attach a database without the corrupted log file
There might be other options out there. This is something that worked for me once but there are no guarantees that it will work at all times. Stop SQL Server instance -> Copy MDF and LDF files to another location -> Delete original MDF and LDF files -> Start SQL Server instance again -> Create new database with exact same name and file names -> Stop SQL Server -> overwrite newly created MDF and LDF. After this your database should be back online. If it is then go ahead and put it into EMERGANCY mode and SINGLE USER mode. Finally go ahead and execute DBCC CHECKDB like this DBCC CHECKDB (databaseName, REPAIR_ALLOW_DATA_LOSS) WITH NO_INFOMSGS More information you can dig out from resources directly connected with SQL Server databases and database corruption in MS SQL Server any version... http://itknowledgeexchange.techtarget.com/itanswers/how-to-restore-mdf-file-as-bakcup-databe/ https://www.repairtoolbox.com/sqlserverrepair.html SQL Server Repair Toolbox
5/12/2016 6:37:51 AM • Microsoft SQL... • Answered on May 12, 2016
How to display the top 5 orders base on the amount due in the specific year using sql
I DON'T HAVE A PRODUCT PROBLEM, I CAN'T AND NEVER COULD RECEIVE MAIL IN MY INBOX, I HAVE SENT SCREENSHOTS AND LETTERS BEFORE THIS IS GOING ON SINCE I HAVE BECOME A MEMBER IN JULY OF 2007!! ALL MY FRIENDS SAY MY MAILBOX IS FULL! BUT WHEN I TRY TO SEND OR READ MAIL I GET A NOTICE STATING THAT THE MAILBOX IS UNOBTAINABLE AND IF I KEEP GETTING THIS MESSAGE GO TO CUSTOMER SUPPORT. PLEASE HELP ME!! TY SANDRA08/30/12 at 03:25 amI DON'T HAVE A SOLUTION AND IT SEEMS THAT POGO DOES'NT EITHER. THEY SAY THEY HAVE BEEN WORKING ON IT SINCE 2007, AND I'M NOT HAPPY WITH THEM ALWAYS PUTTING ME OFF THAT THE PROBLEM NEEDS A HIGHER UP TECH, HOW HIGH CAN YOU GO?? COMMON THIS IS GETTING RIDICULOUS!!! WHY CAN'T I HAVE THE SAME OPTIONS AS ALL THE OTHER PAYING MEMBERS? LOOKING FORWARD TO HEARING A POSITIVE REPLY, TYVM, A VERY UNPLEASED CUSTOMER, SANDRA
6/15/2013 1:09:31 AM • Microsoft SQL... • Answered on Jun 15, 2013
Where to find software solutions?
I am a SQL server DBA. You can reach me at [email protected]
8/6/2010 8:24:01 PM • Microsoft SQL... • Answered on Aug 06, 2010
5answers
Microsoft office Bootstrapper has stopped
tep1: - Firewall Disable The users should try to temporarily disable Firewall or other security programs on their system. Step2: - Uninstall Old version of Microsoft Office If the users have installed the old version of Microsoft Office, then they need to instant uninstall it. In any case, if the MS office does not uninstall by using the Control Panel, then they have to download Microsoft Fix Tool and then use it to remove the old version of office of their PC. Step3: -Install Microsoft Office in Clean Boot Boot the system in the clean boot and then try to install the Office 2013 program and check that the clean boot is performed to disable all startup programs and the third party services on the machine. Also, check if they are conflicting with the Office installation. Then restart the computer in Windows Clean Boot and then try to install Microsoft Office 2013 program. Step4: - Check the Services Is Running Properly The users need to ensure that the following services are running properly in the services console. Go to "Start" button and then go to "Run" command. In the command prompt, type "Services.msc" cmd and tap on "Enter" key.
  • Check the Print Spooler
  • Check the Task Scheduler & respective dependencies
Step5:- Check Internet Connection The users need to ensure that their Internet Connection to the system is properly working or not. Might require download few Microsoft utilities at distinct stages. Step6:- Repair OSE Service Follow these steps:
  • Go to Office "install disc" option, and then find ose.exe and osetup.dll.
  • Then need to create a folder for OSE: C:\Program Files\Common Files\microsoft shared\Source Engine
  • Now copy the "OSE.exe" file to that folder.
  • Then restart your machine.
  • Now try to install Office again.
3/7/2024 12:32:09 PM • Microsoft... • Answered on Mar 07, 2024
Product key for ms office 2010 -X16-32007
Not all office disks have the same codes, no matter the version you may need a whole new installation disk with the corresponding code
2/15/2024 4:22:18 PM • Microsoft... • Answered on Feb 15, 2024
My microsoft intergrated webcam works good on skpe. It will not open for me to video myself offline. can I download the same type without messing up my computer
all you need is a camera program or app that is compatible with your operating system and the computer hardware also check to see that your drivers are up to date
2/15/2024 4:21:26 PM • Microsoft... • Answered on Feb 15, 2024
I WANT THE CONFIRMATION CODE FOR MICROSOFT OFFICE PROFESSIONAL 2007 7 CHARACTERS A,B,C,D,E,F,G
2/15/2024 4:15:17 PM • Microsoft... • Answered on Feb 15, 2024
Microsoft SQL Server 2008 Enterprise Full Version for PC (1 Server/s, 1 Processor/s) (810-07364) Logo
Popular Tags
19 questions posted
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Microsoft Computers & Internet
Most Popular Question
recover data from mdf file
  • Computers & Internet
