Sir,
Try this resource for reliability and accuracy. There is a helpline so you may reflect a personal solution and be given a suggestive application. Having read the file. Section 33 Construction Adhesives & section 11 DAP Silicone Plus will interest you. More and more we are relying on chemistry to help save . Give this resource a look. http://www.dap.com/docs/catalogs/DAPCatalogUS.pdf . Fare. Well.
3m makes a product Marine #5200 that will work even underwater. Probably an overkill. There is also a liquid nails product that works in high moisture areas. Seal the heck out of the piece, particle board loves moisture. My answers are short and sweet. Common sense mostly. If you are trying to get something for nothing...Don't waste my time! Remember if something sounds to good to be true that it usually is. I've spent many years of my life trying to cheat the system and was pretty good at it. This all changed when I discovered that people were doing the same thing to me. What comes around, goes around. Karma! Now I assist people in making win-win deals...that are legit!
no this is overkill. the seem tape is only necessary for seems, screw holes can be covered by a coat of joint compound, and sanded smooth after it dries
I would get a small can of contact cement. Follow directions( ex. coat each side to be glued with each other wait usually 5 min. and then press together.) There is also Scotch spray on adhesive that will also work.
There is no effective long term way to store tubes of silicon. Even unopened tubes have a finite shelf life. I have found the most effective way to store opened tubes for medium lenght time, is to allow a bit of excess to flow over the tip, and allow it to form a plug. In a few months, this plug may extend the full length of the nozzle, but you can push this out with a piece of steel rod (from the tip end). I keep my tubes of silicone and caulking in a cool dry place. I've never tried the bucket of water method, so I don't know how successful that would be.
On pre-mixed buckets, a lot of dry-wallers add just a little water and whip it up when tape and texturing. It flows of the blade better. But, if you're just repairing a few holes, dings and gouges, then no real need............unless it's really thickened up on you.
If you have a partial bucket and are not going to use it for a while, you may want to flick some water on the surface and lay Saran wrap on the surface, then cap the bucket.
The best product that will not harm the poster or window is silicone caulk. There are also some crystal clear adhesives made from silicone now available.
Through necessity when nothing else was available, I found that acetone / nail polish remover dissolves or at least softens superglue.
After the back of a folded tube burst, hands covered in the stuff, I tried various products.
Hand soap, dishwasher, Handy Andy and Methlylated spirits have little effect.
Laquer thinners also helps a bit, although acetone seems best.
Pour full bottle into glass or metal container - not plastic, which will melt..
When rinsing hands in acetone, rub & scrub to remove stubborn bits still stuck.
Concentrate under fingernails, where skin and nail meet.
After removal, re-bottle actetone for future use.
Lanolin oil in skin will also be removed, so after acetone-bath, wash well with hand soap, rinse, treat skin if required with a moisturizer cream.
If your'e a guy, live with it - it'll give your hands a manly, rugged outdoor look! :)
They're not the same thing, spackle is used to fill in holes or indetations made from nails in drywall while joint compounds are used to join drywall panels together.
at least 2. I would suggest to look closely after the second coat dries. if you have a smooth transition than it is fine, if not, a third thin coat should make the finished product look better
Silicone-based caulk is often applied to the underside of bathroom sinks in order for the caulk to seal the gap between the sink and the wall, preventing moisture from getting underneath the sink.
