My masterlink will not properly scan CDS or CDR's placed in it. When I try to burn a playlist to...
(More)
My masterlink will not properly scan CDS or CDR's placed in it. When I try to burn a playlist to CD, it trys scanning the CDR, but then cancels the burn. I'm under the gun on a CD project and I need help ASAP!
I'm getting a disc read error at approximately 45 min of any redbook created cd made on this machine...
(More)
I'm getting a disc read error at approximately 45 min of any redbook created cd made on this machine with several different Sony cdr drives tried. These discs play fine on other machines. What's up? Thanks!!!
My panasonic E55 DVD is no longer show colour image again and I've try all the setting the problem...
(More)
My panasonic E55 DVD is no longer show colour image again and I've try all the setting the problem remain the same. Thanks
The Combined Video & DVD Player has the following cable slots 1 Ant In 2Ant Out 3Euro...
(More)
The Combined Video & DVD Player has the following cable slots 1 Ant In 2Ant Out 3Euro AV2/Decoder 4Euro AV1 5 Component Out 3 Plugs marked Pr Pb &y 6Audio Out 3 Plugs R L &Coaxial 7 S Video Out The Digi Box has the following cable slots 1 VCR Scart 2 TV Scart 3RF1 4 RF Out 2 9v 5 Aerial 6 L & R (2 Plugs) 7 Telephone 8 RS232 The TV has only 1 Scart Socket And RF in Can Anyone help Thanks Confused
When I turn my unit on it says first "system error corrupted playlist" and then it starts...
(More)
When I turn my unit on it says first "system error corrupted playlist" and then it starts a humming noise and reads "HDCD to reset corrupted playlsit" as far as I can tell everthing else is frozen.
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
