20 Most Recent MSI G41TM-E43 LGA 775 Intel G41 HDMI Micro ATX Intel Motherboard (7592-030R) Questions & Answers
Boards don't come with switches. The problem with company made computers is that they get a manufacturer to make a board especially for the case they make. They do this to specifically stop you doing what you are trying to do, upgrade a machine with a proprietary board in THEIR case. You will find trouble at the rear of the machine getting to sockets and plugs.
It is far better to buy a good case, and then you can swap out components with ease. The case that held my Asus boarded P4 with the first SATA drives now has an Asus Quad Core in it with SATA 2.
MSI G41TM E43 LGA 775 Intel G41 HDMI Micro ATX Intel Motherboard Newegg ca
I would contact MSI direct
G41TM E43 MSI Global
Some of this might be useful
G33M - MSI
https://www.msi.com/Motherboard/G33M.html
... the app from the MSI website. Features - Automatically Detect the BIOS/Driver/VGA/Utility Update - Support Microsoft Windows XP/Vista/7 32/64bit. featurePic ...
::UPGRADE:: G33M (MS-7357) - new processor and RAM - MSI Forum
https://forum-en.msi.com/index.php?topic=125215.0 Mar 11, 2009 - 6 posts - ‎2 authors
The motherboard is a G33M (MS-7357) and has a piddly 1.6ghz processor and 1gb of generic RAM. I'm running Windows XP Home.
CPU-Upgrade: MSI G33M (MS-7357) processor support and ...
www.cpu-upgrade.com > MSI Nov 28, 2010 - MSI G33M (MS-7357) motherboard specifications ... FSB 200 MHz, L2 512 KB, TDP 35 Watt, Conroe-L, Rev A1, SSpec SL9XP, 7357v10.zip.
UserBenchmark: MSI G33M (MS-7357) Compatible Builds
www.userbenchmark.com/System/MSI-G33M-MS-7357/450 Compatible Components (from 7 PCs). Popular components in PC builds with the MSI G33M (MS-7357) Motherboard. CPU. Core2 Quad Q6600Intel $190Bench ...
MSI G41TM-E43... | Answered on Oct 21, 2017
Go to the intel site. They have these audio drivers for all intel motherboards.
MSI G41TM-E43... | Answered on Mar 17, 2014
Download the driver from here:
http://www.msi.com/product/mb/G41TM-E43.html#/?div=Driver&os=Win7%2064
Please select your windows system 32 or 64 bit.
Download the vga driver and unzip the file.
Uninstall the old one before you install the new.
Check also your bios for the graphic settings.
My advice is to buy a better graphic card to insert in the pci-e socket instead of using the onboard graphic for better performance.
Good luck
MSI G41TM-E43... | Answered on Nov 06, 2012
Set the resulation proper ,
If you need more information, reply me soon.
Thanks
MSI G41TM-E43... | Answered on Feb 20, 2011
Hello thanks for asking,there are several reasons that can cause this problem,you should try plug your computer into a different wall outlet the present one may have a fault,{2) you can try using a different power cable the one use can be faulty,(3) you can check the connections to the motherboard tho make sure they are correct , the power connector and the 4 pin connector which power the CPU. Try these solutions and let me know if any work
MSI G41TM-E43... | Answered on Jul 22, 2010
yes...only u have to install the dat device's driver
MSI G41TM-E43... | Answered on Mar 18, 2010
This is an old motherboard, with this in mind there are a couple things for you to try. Power off the system and unplug the power cable from the power supply. Remove the left side of you're case. Touch any metal surface to discharge possible static.
First clear the cmos jumper on the motherboard. See page 1-17 in you're manual for the location of the cmos battery and cmos jumper. Also see page 1-21 to clear / reset the cmos battery. (Don't forget to set the jumper back to normal after 30 seconds.
Doing this will reset the bios to its default setting.
If you added a graphics card to one of the PCI slots remove it.
(For now).
Re-connect the power cord for the power supply and power-on the system. If the motherboards built in VGA controller is working you should have display on your monitor and since we cleared the cmos the bios will want you to enter the bios to adjust all its settings.
If you do not have display than the onboard controller is defective. You can add a PCI video card into any one of the 3 (White in color PCI slots). It’s not uncommon for the mouse to stay lit. If you're mouse is plugged into a PS-2 port try un-plugging it when the system is off.
Then re-connect it with the system off. You can also buy a USB to PS-2 adapter. Most new mice and keyboards come with this type of adapter. See the link provided; http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=776087&CatId=469
If you're mouse and keyboard are PS-2 and connects to the system by USB, try another opened USB port. The next link opends to Biostar and you're motherboard;
http://www.biostar.com.tw/app/en/mb/content.php?S_ID=324
Cheers'
Mike
MSI G41TM-E43... | Answered on Mar 09, 2010
just install ur orignal window 7 driver for ur motherboard
http://www.msi.com/index.php?func=proddesc&prod_no=1791
follow this link
MSI G41TM-E43... | Answered on Mar 07, 2010
make sure that your little speaker is plugged in to the correct pins. This gets many people every time. If the speaker isn't plugged into the correct slot you're definitely not going to get anything to work...yeah i know...a silly speaker...you can have quite a few things plugged incorrectly and things will still work but if you have the speaker plugged into the wrong one...then ur dead in the water...find the little cylindrical speaker and try plugging it into a different slot...really look on that board for it. Should be labeled JFP2..connect the speaker to the 4 pin side of that 7 pin connection.
MSI G41TM-E43... | Answered on Dec 21, 2009
Although I've got a different type of MSI but I have where the "official guys" say there should be: at the back of it, maybe you need to remove the battery and look there under "S/N: xxxxxxxx"
MSI Computers &... | Answered on May 11, 2019
that 1996 is not correct (its series name only)
MSI N1996 Motherboard P6NG Neo-Digital MS-7505
the bottom sticker on the mobo tells what it really is.
MSI motherboard, just bought ? used"?
ever see it work before.
did you go to msi.com and the manual on setups"?
are you using the onboard VGA port to a VGA monitor.
The monitor shows no signal means exactly that.
This motherboard has 1 power jacks, the big one 24 pins
and the 4pin at top left of the fan.
you must use PSU v2.2 or newer to get that 4 pin power.
covered on page 24 in your manual, here.
https://www.msi.com/Motherboard/support/P6NG_NeoDigital#down-manual
and CPU and fan, (correct)
and memory
and a power switch to the power switch jack.
next time post all stickers on mobo so we can see what it really is.
they made vast numbers of motherboards. a fact.
MSI Computers &... | Answered on Apr 12, 2019
Well, you could uninstall anything related to the sound device. If you can, I suggest using the sound driver provided by the manufacturer. Let me know how it went, thanks.
MSI Computers &... | Answered on Jan 26, 2019
Beeping mostly means it's trying to give an error code along. Listen to the amount of beeps and the duration of them. This is the error code that it tries to give on. Look up in the manual what the beeps mean and how to solve it.
MSI Computers &... | Answered on Jan 17, 2019
Cheers!!
Need to replace the display flex ribbon cable to solve the flickering and color lines problem. This cable gets damage over the time of long usage.
MSI Computers &... | Answered on Nov 20, 2018
Add more RAM memory.
MSI Computers &... | Answered on Nov 10, 2018
No update will increase the speed.
There may be drivers from the keyboard manufacturer that need to be loaded in Windows.
MSI Computers &... | Answered on Nov 01, 2018
MSI G41TM-E43 LGA 775 Intel G41 HDMI Micro ATX Intel Motherboard (7592-030R) Logo
Popular Tags
14 questions posted
Top MSI Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • MSI Computers & Internet
Most Popular Question
no dvi signal g41tm e43
  • Computers & Internet
