20 Most Recent
Dell Vostro 1520 Notebook Questions & Answers
Dell Vostro with XP - cursor is running rogue and endlessly going backward.
This "can" be malware, but is most likely your pointer device going wonky. First unplug the mouse, trackball, or whatever it is you are using for a mouse. If you are still using an old PS2 connection (round plug), consider getting a USB mouse to replace it.
Plug your mouse back in and see if it solves the problem.
Try a new mouse.
If it's not the mouse (you just said the cursor is moving) it could be that the left arrow on your keyboard is stuck. In that case, rake your keyboard, tap ******* the arrow keys, turn over the keyboard and shake out any large Cheeto crumbs, use compressed air (if possible) to blow the dust out.
Unplug your keyboard from the computer and plug it back in. If you are still using the old PS2 keyboard (round plug), consider getting a USB keyboard to replace it. *** warning
*** warning, do NOT throw out the old PS2 plug keyboard if you replace it. You may need it to get into the BIOS some time in the future if the electronics don't recognize a USB keyboard on boot.
Laptop won power
1. chk cable connections P to notebook if hard wired.2. Make sure you have secure w/less access . 3 chk settings if ok.try now. GL
Hwo to check battery adapter
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Vostro 1520 have cotinous beep
Possible there is fault in the OS , a possible virus could have reset the registry files. You can take a virus scan, use a registry check or repair or finally try to RESTORE the pc to an earlier date.
if none of these work the PC must be reinstalled with the OS and drivers.
Check to see if the audio properties, try to disable and reinstall drivers.
I forgot my password
When you boot up to the log in screen type in administrator to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up
Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
or
control panel user accounts
on the users tab,click the name of the computer administrator you can change the password there
hope this helps
My Dell vostro 1520 screen's gets black staryt
try this.
turn the pc on and hit ctrl+alt+delete (task manager)
if it comes up
click new task,
type in explorer.exe
and click next
it should work but not always
if it does immediately download and run Malwarebytes free version from www.malwarebytes.org.
see if you catch a registry problem
also if you know how when you save malwarebytes to desktop it will show up as MBAM.exe...rename it to winlogon.exe install, update, and run full scan.
Good luck
If this helps you resolve your problem, please
consider giving me a good rating and a quick
"thanks" or "good job".It will help me as well.
Thank you.
Bluetooth & sound
Generally, connecting phones via bluetooth to a laptop just allows for file transfer between the two devices. It is not to input sound from the phone through the speakers of the laptop. You would need a bluetooth audio device for that such as bluetooth speakers or headphones
Code 10 is not starting
This error is basically saying that Windows, for one reason or another, cannot communicate properly with one of your programs. This communication problem is usually caused by out-of-date, missing or corrupt device drivers. ... Select Start > All Programs > Windows Update.
This copy of windows is not genuine
i used to get that also, I wrote down windows numbers from windows sticker on the side of machine, (needed magnifying glass) and went online to windows verify, after they scan it, it came out good
HOWCAN FIND MACADRESS WIFI LAPTOP VOSTRO1500?
Open a command prompt ( Windows key + R to open Run box, then cmd), and type
ipconfig /all
and look for the wifi adapter. The entry labelled "Physical Address" is the MAC address. It will look something like 84-3A-4B-C8-E9-B7
(Your router might want it entered in the format 84:3A:4B:C8:E9:B7)
Cpu overheating
The cooling fins on the processor chip are plugged with dust. The fan may not be turning fast enough. If that's the case you'll need to replace the cooling fan
Wifi hotspot
WiFi will in the laptop will connect to a wireless router or a hot spot. The laptop itself has no hot spot built in.
