20 Most Recent Toshiba NB205-N310/BN Netbook Questions & Answers
Check if it works with an external monitor. If it does your laptop screen may have a problem. However, if it does not work with the external monitor attached, your laptop may have a motherboard issue.
Toshiba... | Answered on Feb 23, 2018
Unplug the external dvd writer and don't plug it in untill after Windows boots.
Toshiba... | Answered on Apr 05, 2017
Make sure you have the correct driver installed for the graphics. Right hand click on the desktop, select resolution and pick a size that fits.
Toshiba... | Answered on Feb 12, 2014
Most likely your laptop. Check the TV manufacturer's website for drivers that will work with your particular TV.
Toshiba... | Answered on Jun 01, 2012
If it's a solder connection you have, then you'll have to desolder it from the motherboard and resolder the new one.
Toshiba... | Answered on Aug 22, 2011
Either that or the air intake ports and the radiator are clogged by dust and dirt. Try to clean them with a vacuum positioned at the intake port - the one the air is sucked in by the fan.
Toshiba... | Answered on Jul 03, 2011
what operating system are you using? You might be able to repair the OS. You can't restore it to two years ago, unless you saved a back-up externally.
Toshiba... | Answered on Jan 15, 2011
Remove the battery and disconnect the power unit. Remove the hard drive and RAM.
Power the netbook up. It should complain that the RAM is too low and the drive is missing.
Power it down and replace the drive and RAM.
That will get it going again.
If it doesn't, you have a mother board fault and need specilised help.
Toshiba... | Answered on Dec 16, 2010
how far does it go into the boot sequence?
Toshiba... | Answered on Dec 04, 2010
I'm assuming you have all the drivers installed and properly configured.
Yes, it appears that a part doesn't start up as it should. Run this program
http://www.cpuid.com/softwares/pc-wizard.html
and check the voltages, if one is low then the board is failing.
Toshiba... | Answered on Jul 12, 2010
The manual on the support page should tell you, but unless you have done this kind of thing before I would not try.
I have built a few pc's and repaired many pc's and laptops. and i would not want to try that.
Toshiba... | Answered on Jul 11, 2010
you probably need intel graphic media software go to Cnet this will help with the video/picture
  • http://download.cnet.com/Intel-Graphics-Media-Accelerator-Driver/3000-2108_4-10300119.html
feel free to rate the help
Toshiba... | Answered on Jul 02, 2010
Toshiba NB205-N310/BN Netbook Logo
41 questions posted
Top Toshiba Computers & Internet Experts
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Computers & Internet
Most Popular Question
am trying find free user manual download
  • Computers & Internet
