20 Most Recent
Sony Ericsson W350A Cell Phone Questions & Answers
How to format my sony
HELLO, Sony Ericsson Secret Menu:
> means press joystick or arrow keys to right
1. push joy stick to RIGHT once
2. press *
3. push joy stick to LEFT twice
4. press *
5. push joy stick to LEFT once
6. press *
The Service Menu will appears containing following information !
1. Service Info
a. Software Version
b. SIMlock
c. Configuration
2. Service Setting
a. Contrast
3. Service Test
a. Display
b. LED/Illumination - *This test is very cool
c. Keyboard
d. Buzzer
e. ********
f. Earphone
g. Microphone
h. Real Time Clock
i. Joystick Counter*
Lockstatus:
Shortcut to last dialed numbers: 0#
Shortcut to sim numbers: On main menu type a number and press #
If you change the language from default to any other language,
then it may be difficult to switch to default language.
The shortcut is very simple. Just press
stands for right arrow button or joystick.
Hope this helps
Fogot my unlock code for mysony ericson
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
Downloading pictures for a W350a
Purchase an M2 memory card. They are a fraction of the price online (http://www.cellphoneshop.net/m2.html)2. Download PC Suite from http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/pcsuite/w350a?cc=us&lc=en3. Run PC Suite BEFORE ATTACHING THE CELL PHONE.4. Attach the data cable that should have come with the phone, if not, they are also available online (http://www.cellphoneshop.net/usbdacadfors5.html)5. a)Choose Phone Mode on the phone to edit/add/delete contacts, calendar, etc. through PC Suite.b)Choose file transfer to add music, images, and video. After choosing "file transfer," there should be a new drive in My Computer, put the music in the music folder.Source(s):http://www.cellphoneshop.net/m2.htmlhttp://www.sonyericsson.com/cws/support/softwaredownloads/detailed/pcsuite/w350a?cc=us&lc=enhttp://www.cellphoneshop.net/usbdacadfors5.html
Open line
If you wanna unlock your Sony Ericsson mobile , prefer unlock codes , unlocking via codes is the best & safest method for unlocking the mobile , get the unlock code here
wickedunlock , using unlock code specified in it proceed unlocking your mobile & gain solution ...
It was give to me
one reason is that , your phone is network locked which makes it imppossible to use other SIM cards, you can unlock it using unlock codes from
http://www.simpleunlocking.com/
P.S> the above links specified by
azkehhobe returns to a Blank Blogsopt site
Can i get my puk code back
Hello
Thank you for using Fixya!!
The PUK code requested is an unique code to each phone. At
the link below you will be directed to a tip i wrote on how to recover
your PUK code.
Click HERE to navigate.
Kind regards
Lock123
Hi wat is the shortcut to turning the blue tooth
hey brian
in this model there is no short cut for blue tooth as such but you can set a short cut by personalising your short cut keys like your joystick keys or even your selection keys.
hope it helps
