20 Most Recent Kenmore 15919 Built-in Dishwasher Questions & Answers
"AIR DRY" LITE IS ON. I CANNOT GET TO GO BACK SO I CAN START IT AGAIN
Kenmore 15919... | Answered on Jul 15, 2013
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Kenmore 15919... | Answered on Oct 27, 2011
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Kenmore 15919... | Answered on Jul 16, 2011
When a unit has an issue draining one of the first things to check on the unit would be to listen if you can hear the sound of the Drain pump activating. If the Drain pump were makeing sound and running then first your would go under the sink area and disconnect the drain line that goes to either the garbage disposal or sink. After disconnecting the drain line you would look inside where the drain line connects to to assure there is no blockage in the port hole area that the water flows. If you do not see a blockage here then you would have no choice but to pull the unit out from under your counter and check the oppisite end of the drain line as well as the drain pump itself. Also there is a float switch located near the water inlet valve that when activated signals the pump to start pumping out the water. It is also sugggested to remove the drain pump if you do not hear it running an take an old extension cord and cut off the female end. After you remove the female end of the extension you would then add two cclip electrical connectors to the extension cord this would make a powered jumper wire. You can then plug one side into the pump and the other side into a outlet which would activate the pump and allows you to visually assure that the impellar is spining. If you have any further questions message me back Thanks Rick
p.s please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future Thanks again Rick
Kenmore 15919... | Answered on Jul 05, 2011
Hello, Thank You for using FixYa. I will be helping you today.There is a thermal fuse on the control. It is connected to the side of the control inside the door.It is either a white fuse with two wires connected or a round fuse with two wires check them for continuity.
Thank You and please rate my answer if it was helpful..
Kenmore 15919... | Answered on Jun 15, 2011
yes, it sounds like a fuse, or a circuit breaker tripped, or, if it is a plug-in connection, it may have come unplugged(outlet usually under sink. Might also have a loose connection in dishwasher connection box ..CAREFUL HERE;VOLTAGE MAY BE PRESENT!!!
...IT MAYBE THE DOOR IS NOT FULLY PUSHED IN TO ENGAGE SAFETY SWITCH
Kenmore 15919... | Answered on Feb 21, 2010
I am waiting on a heating element. Once installed, we hope the problem is resolved.
Thank you.
Kenmore 15919... | Answered on Jun 04, 2009
email me at b4829@yahoo.com please we will chat
Kenmore 15919... | Answered on Apr 06, 2009
I don't know that I would call it "normal", but it's certainly not surprising. The typical life span of any major appliance is probably in the neighborhood of 12 to 20 years, and electronic components are often the first to fail. Watch for a sale on a new dishwasher (especially a model that may be a year or two old) and dig out your wallet.
Kenmore... | Answered on Apr 26, 2019
Kenmore 15919 Built-in Dishwasher Logo
22 questions posted
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Dishwashers
  • Kenmore Dishwashers
Most Popular Question
power control panel but dead
  • Dishwashers
