20 Most Recent
Sharp LC52SB57UN LCD TV Questions & Answers
Forgot secret code to access restart
CLEARING THE SECRET NUMBER
If you forget the secret number, clear the secret number using the following procedure.
1 Select an item from the list below to display the secret number input screen. (For operating the on-screen
display menu, see page 17.)
• "EZ Setup", "CH Setup", "Parental CTRL" or "Reset" on the Setup menu.
• "Color System" on the Option menu.
• "Software Update" on the Digital Setup menu.
2 Press and hold both CHr and VOLk on the TV simultaneously until the message appears on the screen.
When I cut on my
If both are lit and blinking then the tv is in protected mode - the protection system of the power source has detected that a part has failed and it's acting like a short so it has shut down the power source to protect it and the rest of the tv from further damage.
The only way to find out what part has failed is to open the tv and have the voltages on the power source verified - the one that is near to 0 will be the one that has triggered the shut down. Follow it and you will find the failed part. You need at least a basic experience in electronics to do this job, if you don't have it then call someone who has. And keep the tv unplugged from the mains, it will limit the extent of the damage.
My sharp tv (model lc52sb57u)
The reason the television has its green light flashing is a sign that there is a power problem with the television.
Most likely, it is the power panel or a capacitor on it that is faulty.
Have it checked and corrected and your television will be okay once again.
Take care
