20 Most Recent
Philips SPC520NC Web Cam Questions & Answers
Philips sp520nc, the image
Sounds like a driver has become corrupt.
DO THIS:
Follow the instructions below and it will work.
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program.
When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web, do this.
Web Camera's have to be setup on the program they are to be used with. Just installing the
camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype
http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/
set it up as follows:
Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
Then click on the Video Settings.
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger
http://www.soft32.com/download_30.HTML
Go to Messenger at the top left and click on it.
Next go down to Preferences and click on it.
Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
Next go to the Test Audio section and (in blue writing) click on "Open the call setup assistant" and follow the instructions on the left window.
C. Windows Live Messenger:
http://download.live.com/Messenger
After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar".
Next go to the Menu Bar on right side, click on " "Action."
Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger:
http://dashboard.aim.com/aim
On the VIM sign-in window click on Edit.
Then click on Settings Enhanced IM.
Next click on Enhanced IM.
Then click on Audio Video.
The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
The audio and camera should function now.
Additional information to use with VIM settings.
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently
Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM
Conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working
Properly. Follow the on-screen prompts.
Notes:
The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button.
The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly.
images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the
Picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends.
Hope this helps. Bud
I have the driver for my philips spc520nc webcam,
Philips have an excellent support system for their products - try here
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?tmplt=ePlatform%20-%20Philips&scy=GB&slg=ENG&sct=WEBCAMS_SU&cat=WEBCAM_HEADSETS_CA&grp=PC_AND_PHONES_GR&session=20091209021348_117.47.129.63&ctn=SPC520NC/00&mid=Link_Software&hlt=Link_Software
How to disable theft mode on monitor philips? 276E 4K
The theft deterrence option is available from the SmartControl software that runs on a Windows PC connected to the 276E monitor. See
https://www.usa.philips.com/c-p/276E8VJSB_27/4k-ultra-hd-lcd-monitor/support . Scroll down to the Software & drivers section. Then unzip the file to install it.
Inside the software, the theft deterrence item is under the Options section of the menu. Since a PIN is needed to enable or disable the "feature". It seems unlikely to be enabled accidentally. Did someone else use the monitor for a while? Are you using a different computer with the Philips 276E?
I hope this helps.
11/14/2023 12:35:19 AM •
Philips...
Answered
on Nov 14, 2023
Image flashes for one second on screen then goes away
There could be a few different issues that could cause the behavior you're describing. Here are a few possibilities:
HDMI connection issue: Make sure the HDMI cable is properly connected to both the TV and the laptop. If you're using a HDMI splitter or HDMI switch, make sure those are also properly connected.
HDMI port issue: If you've tried multiple HDMI cables and still have the issue, there could be an issue with the HDMI port on the TV or laptop. You could try a different HDMI port on the TV or laptop, or use a different device to see if the issue persists.
Display settings: Make sure the display settings on the laptop are set to display on the external monitor (the TV in this case). If the laptop is set to display on the built-in monitor, it may cause the display to flash on and off.
Hardware issue: If none of the above solutions help, there could be a hardware issue with the TV or laptop. It's possible that the display controller or other hardware component is faulty and causing the display to flash on and off. In this case, it may be necessary to have the device repaired or replaced.
I hope this helps! If you have any further questions, please don't hesitate to ask.
12/30/2022 2:00:34 AM •
Philips...
Answered
on Dec 30, 2022
I CANNOT PLAY REGION A DVDS ON MY 3D BLU/RAY
No disc in tray Press Home Scroll to settings input code: 13893108520 The settings will pop up and you will see that the DVD region is now set to 0 (meaning region free). I have checked the hack on a BDP8000 (region 2)and it sets the region to 0 (the 7th. digit from the left) alright, but it does not make the player region free as a message from the disc (MGM) comes and tell that the disc is not supposed to be played in this region. The region on the player can be changed to the region by changing the "x" in 138931x8520 to the actual region you want to play.Try this out. The hack codec for blue ray are not yet published so it is not possible to make Blue Rays totally region free as of now.
6/15/2022 12:51:36 PM •
Philips...
Answered
on Jun 15, 2022
Philips streamium bios battery?
NO model toldwell in a shop lacking the $100 service manual what do they do?amazing fact they look inside for any coin cell at alljust look, firstdismantle it look/some have sockets and others are soldered down or , there is no such thing.why not stated what works and does not and ask fordiagnostics help. steps.yes batteries fail, all there not changed out yet?if only remote dead it too has batteriesis UNIT DEAD is screen dead, or stuckis wifi only failing.is it struck in stand by mode?page 33 do the RESET YET?lost AC powerlost AC power pack or using the wrong pACK>water dripped in to the unitlclicker dead.no evidence told so answers will be impossible.Philips NP2500/37 WiFi Internet Radio Network Music Player with Rhapsody my wide guess on real name.did you read trouble page in your lost manual.?but only covers wifi. https://www.download.p4c.philips.com/files/n/np2500_37/np2500_37_dfu_eng.pdf
5/25/2022 1:11:17 PM •
Philips...
Answered
on May 25, 2022
My philips 191EL LED monitor
simply long press input and power touch buttons to reset the ic program and it will be ok be sure to wait 5-10 seconds note: be sure the led has display input and powered on with the problem your encounting thanks ok
5/8/2022 10:20:59 AM •
Philips...
Answered
on May 08, 2022
The press 8 seconds or more does not work with my Philips 227E monitor. Can someone help? Thanks
now a photo review on just buttons (physical) on MON 227E
open the window (physical) in room to get some sun light.
or use a TORCH (usa flashlight )
and look at all 6 sides of the monolith, main display panel
go slow and just look first, as the manuals do stink at makers site (new ones)
next see year and real models, only manuals matched work
learn to tell model, and or learn to google them by exact model
or go to philips.com and get it for free.
2012 models too, 10 years ago and are not the same.
one some the model is full and on the bottom stand label.
older 2012 ,227e4LHab/00(Germany)
that is the best I can do , this side of huge pond
we have none here,.
3/25/2022 4:25:29 PM •
Philips...
Answered
on Mar 25, 2022
