20 Most Recent Asrock K10N78M Motherboard Questions & Answers
Power switch
the heatsink on the cpu is not fast enought
5/9/2014 6:46:02 AM • Asrock K10N78M... • Answered on May 09, 2014
Cpu shuts down automatically after running for a few minutes
open the cpu cover. check your cpu fan on the processor weather it is running. and check the heat sink is tightly fixed on.
11/26/2013 1:49:44 AM • Asrock K10N78M... • Answered on Nov 26, 2013
Wont power up
My wont turn on too, There is a orange light on the tower, Green on the left, Battery ovel, If I push the restart button, also switch the power supply switch in the back, also unplug from it, Sometimes does it, Do ou know whats causing this to happen, Please let me know Thanks
3/4/2013 3:02:35 PM • Asrock K10N78M... • Answered on Mar 04, 2013
Ethernet connection
If you are trying to connect through a modem/router the driver it should have come with a disk provided by your ISP
you might have to connect the usb lead to your modem to get a connection then click start control panel,administrive tools,computer management,device manager scroll to network adapters should see a yellow question mark? right click install drivers http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000- 2112_4-91313.htm make sure your modem/routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection hope this helps
3/21/2011 1:51:48 AM • Asrock K10N78M... • Answered on Mar 21, 2011
The max shared memory of the onboards graphics is
Looking through the manual, see page 6 Graphics.
Max. shared memory 512MB. See (CAUTION 5).
The maximum shared memory size is defined by the chipset vendor and is subject to change. Please check NVIDIA® website for the latest information.
Cheers'
Mike
6/30/2010 5:59:08 AM • Asrock K10N78M... • Answered on Jun 30, 2010
2answers
Press Dell immediately after starting the pc.
3/26/2010 7:52:35 PM • Asrock K10N78M... • Answered on Mar 26, 2010
Gigabyte GO-C61LA 9-in-1 Flash Memory Card from a
The answer to your question is you can use it but with no 1394. If you need the 1394 then you will need to buy an expantion card. your motherboard has 2 usb 2.0 headders. If you need more help let me know.
11/1/2009 12:59:34 AM • Asrock K10N78M... • Answered on Nov 01, 2009
Asrock h110 disable on board video using cards for mining only
real asrock mobo told ,just the intel chipset code H110the bios controls that in bios disable iGPU. no cpu told either as some have no igpu at all.like xeons, and some mobo can run both i3+ and zeons.see this search at asrocksee how your post has no real clues?https://www.asrock.com/support/index.asp?Model=h11029 mobo made based on only intel chipet.
5/7/2022 4:02:49 PM • Asrock Computers... • Answered on May 07, 2022
Asrock h110 disable on board video card
double posted you?of 29mobo not one told.https://www.asrock.com/support/index.asp?Model=h110the bios page,labeled, igpu (disable /enable ) is there.some mobo allow zeon here with zero igpu.but not yoursthey make h110 ,mobo just for useless now, bitcoin mining.watch the netflix movie how the blocked mining,then save moneyalso learn what ROI is?
5/7/2022 3:59:28 PM • Asrock Computers... • Answered on May 07, 2022
3answers
No display on my Asrock P4I45GV
Check Ram and fun if not properly installed
5/7/2022 2:12:39 PM • Asrock Computers... • Answered on May 07, 2022
2answers
Asrock G31M-S No Display/not Booting
First of all, check if there are any inflated capacitors, if there is even one- ditch MBO, other capacitors will soon follow. If no inflated capacitors proceed with these diagnostic steps: 1/ disconnect all peripherials (DVD, HDD, card reader...), leave only MBO, PSU and RAM (and CPU of course); if nothing happens 2/remove CMOS battery (CR2032) for 20-30 sec with power cord disconected from computer, that will reset BIOS; 3/ take out RAM sticks, then, if you have more than one stick, try with each stick separately (it might be faulty RAM); 4/power on MBO without any RAM-if speaker is present it should give BEEP signals; 5/ try with different PSU, many power supplies are faulty even when they do give power to MBO. If nothing of above does not help than you have faulty MBO, because CPUs are so rare to fail that in my 10 years of experience in PC service I had 3-4 fried CPU-s, and even that was because costumer tried to clean PC, removed CPU cooler and than incorrectly placed it back or didn't put thermal paste afterwards. asrock-g31m-s-no-display-booting-yuc33qzjuwfqgyyin4u45syc-4-0.jpg
5/7/2022 1:13:35 PM • Asrock Computers... • Answered on May 07, 2022
MY ASROCK MOTHERBOARD OUTPUT DEVICES IS NOT WORKING
3 post all the same mobo and all 3 same reasons. and all 3 same answers. zero no I added one, coin cell is dead at 7 years, you are 2004 to 2018 late to the party. 14 year old battery is 2 times spec life. for sure.
12/29/2021 4:42:52 PM • Asrock Computers... • Answered on Dec 29, 2021
Factory reset windows 8.1 error
Wipe the hard drive and do a clean install, not repair.
9/21/2017 1:33:46 AM • Asrock Computers... • Answered on Sep 21, 2017
This is my system, -K10N780SLIX3 wifi Mobo -Gtx
swapping out parts, try with different power supply pull the ram reseat it maybe one at time. different memory slots. change one part at a time with good working part, never assume any part is good.
4/19/2017 12:36:24 AM • Asrock Computers... • Answered on Apr 19, 2017
Crack windows 7 activate
That would be ******* and we don't so that here. Sorry.
7/9/2016 6:11:53 PM • Asrock Computers... • Answered on Jul 09, 2016
Instalar windows 8
Si ustedes quieren activar Windows 8 necesita una clave de producto, te tengo este enlace para obtener algunos m?s estables: https://plus.google.com/117868268119072465334/posts/XuMyoTaUjN7.
6/8/2016 6:53:27 AM • Asrock Computers... • Answered on Jun 08, 2016
Asrock K10N78M Motherboard Logo
8 questions posted
Top Asrock Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Asrock Computers & Internet
Most Popular Question
power switch
  • Computers & Internet
