20 Most Recent Kenmore 24 in. 17362 / 17364 / 17369 Built-in Dishwasher Questions & Answers
0answers
Kenmore 587.1616 - upper sprayarm doesn't move -
remove chopper, clean screen on chopper.
11/23/2011 1:15:53 AM • Kenmore 24 in.... • Answered on Nov 23, 2011
Kenmore Dishwasher takes excesive amount
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
3/24/2011 4:43:43 PM • Kenmore 24 in.... • Answered on Mar 24, 2011
It has not been cleaning very well and last night
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
3/4/2011 9:33:12 PM • Kenmore 24 in.... • Answered on Mar 04, 2011
Lights on front are on ie. it has power, but will
Could be the door latch switch is defective.
2/14/2011 5:25:40 PM • Kenmore 24 in.... • Answered on Feb 14, 2011
Something is in the pump blocking the water from getting out. Take the diswasher out if it is installed into a cabinet. Disconnect the drain hose. Turn the dishwasher around and remove the pump and clean it out. If there is nothing inside the pump then the pump is broken and you must replace it. Generally the pump is not working.
1/11/2011 6:43:53 PM • Kenmore 24 in.... • Answered on Jan 11, 2011
There appears to be a
Here is a tip that will help you with how to clean that dishwasher up and get it smelling good again...
Dishwasher Maintenance
heatman101
9/18/2010 4:32:00 AM • Kenmore 24 in.... • Answered on Sep 18, 2010
17362 unit does not drain.
Does this happen with all cycles - like the short rinse cycle as well.
If this is happening only with longer cycles only then check if the water is hot when it stops.
If this is happening with all cycles then it could be pump or controller.
Happy to help further when you provide response.
8/18/2010 11:26:56 PM • Kenmore 24 in.... • Answered on Aug 18, 2010
Kenmore 17369
The problem is your water inlet valve.
If you remove the panel at the bottom of the dishwasher you will see either a copper hard pipe, or a flexible steel hose leading into the water inlet valve.
BE SURE TO CUT OFF THE WATER SUPPLY. It is probably located under the kitchen sink- just follow the water line until you see a cutoff handle.
Now (or first, if you prefer) cut off the power to the dishwasher, or if possible, unplug it. The valve is activated by an electromagnet (called a solenoid)- carefully remove the plug from the side of the solenoid (its best to use pliers so that you don't accidentally yank the wires out of the plug) on the valve.
Now, loosen the nut that connects the water line to the valve (a small adjustable wrench works best, but it's a tight space, so be patient.) disconnect the water supply hose and remove the valve.
Check and see if the screen (just inside where the water supply line connects to the valve) is clogged with limescale. If it is, you can clean it out fairly well with CLR or Limeaway, and that might fix your problem. If it doesn't you can order a new one online, or take it to an appliance parts store if there is one in your area. They are pretty common. If you do order it online, be sure to look it up using the model number of your unit (usually on a sticker on the inside of the door. Different models might use sightly diffferent valves depending on where under the machine they are attached.
Good Luck!
7/25/2009 9:36:04 PM • Kenmore 24 in.... • Answered on Jul 25, 2009
I have a kenmore 66516822000
Check below -
Door switch
The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring
Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch
Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
Good Luck!!
Thanks
6/20/2009 7:25:13 PM • Kenmore 24 in.... • Answered on Jun 20, 2009
Kenmore Dishwasher 17369 not thoroughly cleaning
The first is to look for filters and drains to clean. Also check out the jets, as sometimes these can be clogged farther back than you can see with a quick inspections. You can likely remove them and take a good look. Secondly, you may want to switch detergents. Perhaps the quality of the water you are using has changed, hard water build up or you have changed detergents. You have to find the right detergent for the kind of water you are using, especially if you don't have a water softener. where the filter in the bottom of the dishwasher needed cleaning out. Just take the screws out, pull the plastic filter out and clean. Hope this helps. Report
4/19/2009 12:28:47 PM • Kenmore 24 in.... • Answered on Apr 19, 2009
Noisy cycle and dirty dishes
Hi
If your dishwasher seems noisy, check these:
Water-inlet valve An aging water-inlet valve can sometimes fail slowly, rather than all at once. It can shudder on and off rapidly, causing the incoming water lines to shake, rumble, and rattle--sometimes violently. If yours is doing this, replace the inlet valve.
Motor If it's the motor that's noisy, either of these may be the "culprit:"
  • As motor bearings wear out, they can become quite loud when the motor runs. They wear out quickly if they frequently get wet, because the water washes away the motor bearing grease. Bearings can get wet if the spin seal is defective. Then there will also be water leaking onto the floor beneath the dishwasher. Replace the seal if it leaks (read about the main tub seal in the "It leaks" section, later).
  • If, from beneath the dishwasher, you can see a round, plastic disc that's mounted to the top of the motor (a "slinger"), it may have broken free of the motor shaft. If so, it could be rattling around the shaft while the motor is running. If that's the problem, you need to replace the motor.
Heater fan If the heater fan bearings are rusted or worn, they may squeal, or scrape loudly during the drying cycle. If this is the problem, replace the fan motor. Alternatively, the fan blade may be loose. If so, you need to replace it.
Pump Small fruit pits, toothpicks, and fragments of glass sometimes get stuck in the pump. When this happens, open the pump and remove the debris. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher.
To get to the pump, you usually need to remove the lower rack, the spray arms, and the spray arm support from the inside of your dishwasher. A dishwasher pump isn't obvious. Look for an impeller--a round, plastic fan blade-type device that spins around and pushes the water toward the drain. When you can see the drain impeller, you should be able to see the clogging debris.
Please accept the solution and revert for any further assistance.
Thanks
Rylee
3/25/2009 12:37:36 AM • Kenmore 24 in.... • Answered on Mar 25, 2009
Top rack arm doesn't spin.
matt, did you get down to the chopper screen? If that screen is clogged the flow to the upper arm will be restricted. Check out the pic, Catriver
3/11/2009 6:56:07 PM • Kenmore 24 in.... • Answered on Mar 11, 2009
Dishwasher runs for a long time
If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating Yourdishwasher may pre-heat the water. If so, and if the water entering thedishwasher is cool, the heater may take up to half an hour to heat thewater.
To avoid the wait, increase the incoming watertemperature before turning on the dishwasher. Do that by running thekitchen sink faucet until the water runs hot. Or increase thetemperature of the hot water to the entire house at the hot waterheater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
12/23/2008 4:18:22 AM • Kenmore 24 in.... • Answered on Dec 23, 2008
2answers
AEG Dishwasher
Are you using these all in one tablets? if so I would still advise to add salt as without this you will get limescale build up espesially if you are in a hard water area, hopefully this will solve your problem.
11/6/2008 3:12:43 AM • Kenmore 24 in.... • Answered on Nov 06, 2008
Strong smell during sensing cycle
Visually inspect the heating element to make sure there is nothing on it, like plastic residue or something like that. You might also want to clean the dishwasher with vinegar, CLR, or Dishwasher Magic ( http://www.appliancepartspros.com/accessories.aspx?part_id=2675393&cat=62&rdr=%2faccessories.aspx%3fcat%3d62 ) Hope this helps, APP Tech http://www.AppliancePartsPros.com
8/8/2006 6:18:03 AM • Kenmore 24 in.... • Answered on Aug 08, 2006
Kenmore 24 in. 17362 / 17364 / 17369 Built-in Dishwasher Logo
27 questions posted
Top Kenmore Dishwashers Experts
vince
Paul Carew
NOEL
NOEL
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Dishwashers
  • Kenmore Dishwashers
Most Popular Question
kenmore dishwasher 17369 not thoroughly
  • Dishwashers
