A quick fix for most communication errors can be
achieved by resetting the printer and/or rebooting the PC. Simply disconnect
the printer from your computer. Reboot your pc. Unplug and re-plug the printer
into the power source to reset it. When the printer turns on, reconnect it to
your computer. Then try to print again once the computer fully recognizes the
USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer.
Pull out the power supply, black box where the power cord is plugged in at the
back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers
and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB
connection. To check, go to Control Panel > Printers and Faxes. If you see a
new Lexmark print object in the list, then try to print a document again to
verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/u5uUiR. Select your operating system, download and execute the file.
Note: You can make a quick color or black and white copy.
Press Color Copy or Black Copy on the control panel.
To make black and white, gray, or color copies:
1 Open the top cover of the All-In-One.
2 Place the item you want to copy face down on the glass. Make sure
the upper left corner of the front of the item aligns with the arrow.
3 Close the top cover.
4 Open the Lexmark All-In-One Center (see page 3).
The All-In-One Main Page displays.
5 Click See More Copy Settings to review and change the copy
settings.
6 Select your copy settings.
Note: You may want to reduce or enlarge the image.
7 Click Copy Now.
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
49 questions posted
1,487 Questions
1,353 Questions
1,277 Questions
961 Questions
741 Questions
