20 Most Recent
Canon ImageCLASS D1120 All-In-One Laser Printer Questions & Answers
When doing auto feed on
I just did what Dick Davis said. I also noticed that there was a long plastic strip on top of this little glass area to the left of the main glass area. It had little handles on the top and bottom that allowed the piece to pop on and off. I took this piece off and cleaned both it (it was clear plastic for the most part) and I also cleaned the glass strip that it was on. Then I tested a couple prints and Voila!, the printer is now printing without the line going down the page using the auto-feed.
Canon imageclass D1120 printer says:
Hi Try this method
To "Settings/Registration Table"
You can specify the method for restarting scanning of documents when a paper jam occurs in the feeder.
For information on the optional products required to use this function, see "Optional Products Required for Each Function."
- Press (Settings/Registration) ? [Function Settings] ? [Common] ? [Scan Settings] ? [Feeder Jam Recovery Method].
- Select [From 1st Page] or [From Stopped Original] ? press [OK].
Details of each item are shown below.
[From 1st Page]:
If a paper jam occurs in the feeder, scanning starts again from the first page of the document.
[From Stopped Original]:
If a paper jam occurs in the feeder, scanning starts again from the page of the document scanning was interrupted.
Red light flashes, screen says "load correct paper: A4." The paper is alreay loaded. I cannot print.
When <LOAD CORRECT PAPER> appears on the display, the size of the
paper in the paper cassette or multipurpose tray is different from that
of the paper specified in <PAPER SIZE> for <CASSETTE> or
<MP TRAY>. You need to load the correct size paper or change the
paper size in <PAPER SIZE> for <CASSETTE> or <MP
TRAY>.
Check if the size of paper loaded in the paper cassette or multi-purpose tray meets the paper setting specified in the machine.check the following:
1. The paper size specified on the printer driver screen
2. Paper loaded in the machine
3. The paper size set in <PAPER SIZE> for <CASSETTE> or <MP TRAY>If you need any technical help on printer then you can reach at
http://www.vtechsquad.com/
Our canon D1120 has started
you can reset Dept.id and password.
press additional function and then 2 and 8
now go to clear
clear password and restart machine.
