20 Most Recent
Samsung HT-X70 Theater System Questions & Answers
Hello my Samsung HT-x70 plays for about 20 minutes
First check in back that the fan is running. Second: Remove cover and check for bad capacitors in the back right corner. The ones in my system were blue. one had totally dissolved. I replaced the capacitor ad the system worked fine, Then found the fan was not running so replaced that too. It does take some soldering to repace the capacitor.
Samsung ht-x70 problem at loading dvd, it stay at
I AM HAVING SAME PROBLEM WITH MY HT-X70 I HAD FOR ABOUT 3 YEARS NOW. I OPENED IT UP AND DUSTED THE LASER OFF BUT STILL NO LUCK. ONLY THIN I CAN THINK OF IS LASER IS BURNT OUT AND NEEDS TO BE REPLACED
First time in two years
Well first of all you check the wireless chip you insert behind the main unit. check that the chip inserted properly or not.
If further you have the same problem then let us know - When you pressed 0-1-3-5 on the remote and then turned the main unit on, did you use the power button on the remote or on the main unit? Whichever you did, try the other one and follow the rest of the sequence. I would think that it would be on the remote, such as 0-1-3-5-Power.
- You're holding the ID SET button for five seconds, correct?
Thanks
Hi, I'm using the Samsung HT-E330K. It works but does not speak out. The power display is fine but no sound
If your Samsung HT-E330K home theater system is not producing any sound even though the power display seems to be working fine, there are several potential causes and troubleshooting steps you can try:
1. **Check Volume Levels:** Make sure the volume on the home theater system and the connected TV (if applicable) is turned up and not muted.
2. **Check Audio Source:** Verify that the correct audio source is selected on the home theater system. If you're using multiple input sources (DVD, TV, AUX, etc.), make sure the right input source is selected.
3. **Audio Cables:** Ensure that all audio cables are securely connected to both the home theater system and the audio source (TV, DVD player, etc.). Sometimes, loose or faulty cables can result in no sound.
4. **Speaker Connections:** Check that all speakers are properly connected to the home theater system and that the speaker wires are securely inserted into the appropriate terminals.
5. **Audio Settings:** Go through the audio settings on both the home theater system and the connected TV (if applicable). Ensure that the correct audio output settings are configured.
6. **Mute Function:** Double-check that the mute function on the remote control or the home theater system itself is not engaged.
7. **Speaker Balance:** Check the speaker balance settings to ensure that sound is not unintentionally directed to one side or speaker.
8. **Reset to Default Settings:** If you've made any changes to the settings recently, consider performing a factory reset to revert to the default settings.
9. **Firmware Update:** If there is a firmware update available for your home theater system, consider updating the firmware as it might resolve any software-related issues.
10. **Test with Different Source:** Test the home theater system with different audio sources to rule out issues with a particular device.
11. **Test Speakers:** If possible, disconnect each speaker one at a time and test the audio to identify if a particular speaker or speaker wire is causing the issue.
12. **Check Speaker Impedance:** Ensure that the speakers' impedance matches the specifications of the home theater system. Mismatched impedance can affect sound quality.
13. **Contact Support:** If you've tried these steps and still have no sound, consider contacting Samsung customer support or seeking assistance from a professional technician for further troubleshooting and repair.
Remember to refer to your device's user manual for specific instructions related to your model.
