20 Most Recent Sony Ericsson HBH-DS205 Bluetooth Earset - Wireless Connectivity - Stereo - Earbud - Dark Gray Headset Questions & Answers
Hullo Tillgustaf
I understand you need an A2PD compliant bluetooth adaptor. I’ve just installed one on my PC at work, asked Windows to look for updated drivers on the internet and it has installed correctly.
You can get an A2PD adaptor from Amazon for £1.50 here
Best wishes,
Phil
Sony Ericsson... | Answered on Sep 11, 2010
The wire to headsets can get damaged (usually not visible from the outside, as the wires inside the covering can be very delicate, to keep the size of the wire down) from throwing them in the pocket, purse, etc. Try a set from a friend to make sure the device is still working itself.
Sony Ericsson... | Answered on Dec 02, 2017
i cant install my themes in sony EricssonW395 even in my mobile i dnt have themes folder in filemanager but themes are their in seetings
Sony Ericsson... | Answered on May 30, 2010
Hello Jeff, I was looking for the user manual of your CB Radio Hatadi, to know what fuse it takes and there is no information
I would try the 5 Amp, I would place it and it would work for a long time to the BC Radio, checking that the fuse resists the transmission work
If it does not resist, I would put the 10 Amp and would do the same test
If it does not resist either, then you already have problems with the equipment
If so, look for a specialized technical service
I hope you can solve the problem
Greetings Franco Dosil
Hola Jeff, estuve buscando el manual de usuario de tu CB Radio Hatadi, para saber que fusible lleva y no hay informacion
Yo probar?a con el de 5 Amp, lo colocar?a y har?a funcionar por un rato largo al BC Radio, comprobando que el fusible resista el trabajo de trasmisi?n
Si no resiste, pondr?a el de 10 Amp y har?a la misma prueba
Si tampoco resiste, entonces ya tienes problemas en el equipo
Si es as? busca un servicio t?cnico especializado
Espero Puedas resolver el problema
Saludos Franco Dosil
Radio... | Answered 24 hours ago
Sony Ericsson HBH-DS205 Bluetooth Earset - Wireless Connectivity - Stereo - Earbud - Dark Gray Headset Logo
Popular Tags
8 questions posted
Top Sony Ericsson Radio Communications Experts
Anthony Ward
Anthony Ward
Håkan Sterner
yobo007
yobo007
Are you a Sony Ericsson Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Ericsson Radio Communications
Most Popular Question
try connect sony ericsson hbh ds205
  • Radio Communications
