20 Most Recent
Flip Video MinoHD 4 GB Camcorder Questions & Answers
Why can't people open/view the
Hello -- (me too on PC savvy - I use a Mac) -- BUT -- being a photographer I download all pictures & video into iPhoto and send to family etc.
What I found was the downloads came in as Mpeg4 and then my email changed it to WMG as i had left the compression mode on.
I had to remove the compression which I found in my email settings and click the do not compress.
Have a look to see what type of file it is inside your photo application - send it to yourself - then open to see if the file format has changed.
(Its also a HD camera so maybe the people you are sending too don't have an application for HD),
Ray
Hi
my Mino HD can not
charge it for 6 hour if make sure you computer does not got to sleep by going into energy saver preferences and move the top dial to never or call flip support at 8882226689 open 24/7
Brand new Flip Mino HD froze & now won't turn on. HELP!
return it for a refund! i bought one, it did the same as yours. i
returned it and bought the 2nd one. It did the same as the first one
(and the same as yours.)
It is a piece of junk. Supposedly the
previous Flips were good, unfortunately, I didn't have the previous
models so my experiences only are bad.
When I try to record, I am told that my Flip
Try this.
Connect to your PC.
Go to MY COMPUTER.
Right click on the Flip Video Drive
Select PROPERTIES from the pop up menu.
Press the DISK CLEANUP button
When the Disk Cleanup window appears press OK
When I put the MinoHD
If your camcorder is unresponsive and will not power on even after charging for several hours, we suggest resetting the camcorder.
There are two methods of resetting the Mino:
- The quickest method to reset the Mino is to hold the power button down for 10 seconds. This should unfreeze the Mino and allow for its normal function.
- Another method to reset the Mino is to simply take a pin and insert it into the reset hole within the camera's tripod mount, wait five seconds before powering on, and then power on without touching any of the buttons on the back of the camcorder for an additional five seconds.
Please note that resetting the camcorder using either method will not affect the videos resident on the camcorder; it will simply reset to the default settings on the Mino.
Pleaes leave me comment, if you need further assistance
Rnj Vinodkumar
Flip Camcorder Model S1240
Since you have already tried the reset then you are done, nothing else can be done to fix this issue, it is a battery problem The batteries are integrated to the internal circuit CCD board and are not replaceable. If I had the camera I would do my best to take it apart and find out what type of battery it uses and then go to eBay and find the correct cell type and replace it. But unless you are very mechanically minded I would not recommend the trouble.
