20 Most Recent LG GH22LS50 DVD-RAM Burner Questions & Answers
0answers
0answers
After i tried to burn a dual layer dvd it got burn
Hi,Try this. Here's How:
  1. Click on the Start button. If you're using Windows XP, also click on Run.
  2. In the search box (Windows 7 and Windows Vista) or the Run textbox (Windows XP) type regedit and click OK or press the ENTER key. This will open the Registry Editor program. Important: Changes to the registry are made in these steps. Take care in making only the changes outlined below. While it's not a necessary step to complete this process, I recommend that you play it safe by backing up the registry keys you're modifying.
  3. Locate the HKEY_LOCAL_MACHINE folder under Computer/My Computer and click the '> or (+) icon next to the folder name to expand the folder.
  4. Continue to expand folders until you reach the HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class registry key.
  5. Click on the '> or (+) icon next to the Class key to expand it. You should see a long list of subkeys open up under Class that look something like this: {4D36E965-E325-11CE-BFC1-08002BE10318}. Note: Each 32-digit subkey is unique and corresponds to a particular type, or class, of hardware in Device Manager.
  6. Determine the Correct Class GUID for the Hardware Device. Using this list, find the correct Class GUID corresponding to the type of hardware that you're seeing the Device Manager error code for.Hope this helps.Regards,Meir
11/10/2011 6:27:55 AM • LG GH22LS50... • Answered on Nov 10, 2011
My dvd writer is not reading the cd which i keep
You just need to download and update the firmware for your DVD drive. You will get the firmware from LG website.
3/29/2011 3:48:09 PM • LG GH22LS50... • Answered on Mar 29, 2011
My dvd drive cant read any ype of disk even all
Your optical drive might be defective. Most DVD-RW drives last less than 2 years. You should get a new one.
3/22/2011 2:53:02 AM • LG GH22LS50... • Answered on Mar 22, 2011
When i put a disc into my burner it shows there
click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area or if this fails to fix the problem make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or your drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem Close all open programs
Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps dont forget to vote
2/11/2011 9:55:03 PM • LG GH22LS50... • Answered on Feb 11, 2011
Still got problems tried last
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.if these fail to fix the problem
It could be a problem withthe lens, you should try cleaning the lens, it's already gone bad there is no harm in trying If you take a little risk can solve . follow the instruction: Don't panic its very simply. 1. When running your pc , open the drawer.> 2. switch off the acpower 3. remove powercable & sata or pata cable 4. remove all the screw from the back side 5. press clip to open the font panel 6. reverse the cd/dvd rw 7. just remove the cover 8. clean the optical lance 9. use a little( not much )oil place on two steel shaft 10.cover all the equipment 11.now you can fit to your pc Ifit does the same problem please change the cd/dvd rw because the lance has defected..
2/11/2011 9:53:53 PM • LG GH22LS50... • Answered on Feb 11, 2011
My dvd/cd rewriter drive shows the disc is empty
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
2/11/2011 7:10:57 PM • LG GH22LS50... • Answered on Feb 11, 2011
Hi i ve got this
don't put too many files on root. put them on a directory will be fine.
12/18/2010 4:50:28 PM • LG GH22LS50... • Answered on Dec 18, 2010
0answers
Not reading all kinds of disc sony and benq cdrw
If your CD/DVD writer is not reading disks at all then there is problem in your drive's lens.
To fix it you have to open the writer and clean the lens .
If you don't want to clean the lens manually then there is a disk called "CD lens cleaner" available in the market , buy it and insert the disk into your drive.
This will automatically clean the lens
But if you want to do it yourself then please follow the below steps.
First of all take out the CD/DVD writer out and remove all the screws and slide the cover to open it.
As you see the lens don't touch it with your finger but clean it with cotton cloth. After cleaning it place the cover and close it.
Now try any disk in it. If it works then you are done.
But if it is not reading the disks then you have to change it.
Hope the above information is helpful to you.
Thanks for using fixya
11/30/2010 5:07:26 AM • LG GH22LS50... • Answered on Nov 30, 2010
Hi there, I've just installed
go to lg to see if there is any patchs to be gotten or it maybe drive is bad jim
11/18/2010 9:18:51 AM • LG GH22LS50... • Answered on Nov 18, 2010
Trying to burn and it
use software like nero burn jim
11/17/2010 10:01:05 AM • LG GH22LS50... • Answered on Nov 17, 2010
Internal target failure while nero
make sure your burner is getting enough power test all the leads that are attached to your burner including electrical extensions making sure they have secure connections or just replace them they might be bad/faulty
11/12/2010 8:08:59 AM • LG GH22LS50... • Answered on Nov 12, 2010
Dvd will not display in
fit sata cable or pata cable again tightly or if you have another cable change it
11/11/2010 11:50:38 AM • LG GH22LS50... • Answered on Nov 11, 2010
I'm having a lg gh22ns50
check your sata cable... If it was working fine, the cable can be with bad contact.
10/11/2010 8:23:42 PM • LG GH22LS50... • Answered on Oct 11, 2010
LG GH22 LS50 (Sata Dvd Writer) Will not write dvd discs
What software do u use to write DVDs on both PCs...
if they are different then that may be the issue....
dont spoil the DVDs....
try DVD RW disks...that way you can erase them later...
i too have the same DVD writer, not had any issue in either XP or Win7....i have dual boot and have made many movie DVDs using both OS...i use Nero and Power2Go of LG(the install disk that came with the LG DVD writer has this great software...."LG Power tool")
try this tool...it should work...
the inbuilt DVD creator in Win7 has some issues with DVD creation....due to non compatibility of graphics card and display drivers (WDDM)....+ you may not have the correct codec required to burn DVDs.....
get the FFDSHOW codec from google.... and install it...shutdown and restart and then try...
let me have a feedback pls...
reg
10/11/2010 8:09:42 PM • LG GH22LS50... • Answered on Oct 11, 2010
I'm not sure what lightscribe
Using lightscribe technology you can burn labels directly onto CDs and DVDs. I don't think that you're DVD writer does affect your PC's OS good operation. Maybe you have a problem with your operating system, it can be infected by a virus or spyware. Ensure that you have an antivirus installed and it's working (you can install Avira and Malwarebytes), do a system scan and see if it's infection free.
If this is the solution for your problem, please rate my post, otherwise give us more details.
Regards,
Andras
9/12/2010 2:17:44 PM • LG GH22LS50... • Answered on Sep 12, 2010
What SATA cables are required
All SATA devices use the same cables. There are 2. The wider one is the power, and the skinny one is for data. They tend to be red in color, and have keyed ends that prevent being put on wrong.
9/10/2010 4:17:41 PM • LG GH22LS50... • Answered on Sep 10, 2010
LG GH22LS50 DVD-RAM Burner Logo
37 questions posted
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
GH LG
  • GH LG
Most Popular Question
internal target failure while nero
  • Computers & Internet
