20 Most Recent LG WM2301HW Front Load Washer Questions & Answers
The drain hose is down too deep into the drainpipe causes some backflow of dirty waste. Needs air gap for atmospheric pressure and gravity do the draining, so the drain hose is down from 4" to max 7" into the stand drain.
LG WM2301HW... | Answered on Jan 08, 2019
Here is a tip that explains what the LE error code means.....
LG Washing Machine LE Error Code or Fault Code
heatman101
LG WM2301HW... | Answered on Sep 12, 2018
Could be:
1. Broken spring(unlikely)
2. Bad shock absorbers (maybe)
3. Broken spyder-the Inner drum part that holds the drum to the hub(kinda likely). If inner drum can be moved without outer tub also moving in tandem, then broken spyder is likely.
Good luck
LG WM2301HW... | Answered on Mar 08, 2018
not sure if you did this already but unplug it for 10 Min and see if it does a reset.
for your reference in case it doesn't help.....
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/46-200-866280-/new/LG-Washer-won-t-start-WM2701HV
hope this helps a little.
this could be a short in the windings of the pump or motor
LG WM2301HW... | Answered on Mar 02, 2018
page 22 of the user manual states that warm rinses are regulated at 86F (30C) it states that there is a heating element as well to boost the temp to normal hot water temperatures (90-100 C)
LG WM2301HW... | Answered on Apr 11, 2017
Rubber seal on the bearings going bad.
LG WM2301HW... | Answered on Mar 08, 2017
An OE error code indicates that the washer was unable to drain the water. The main causes for this error code are a kinked drain hose, a clogged drain pump filter, or a problem with the drain pump itself.
LG WM2301HW... | Answered on Mar 19, 2016
Is your AC supply very stable? The manufacturers repair manual states that the AC supply of 120V may only fluctuate +10% or -15%
LG WM2301HW... | Answered on Jun 08, 2015
You have to clean the filter once a month. Which located lower left. Do a tub cleanse. Rinse extra. That will clear your problem. I have had the same issue and many repairmen and that was the answer. As long as I clean it than grease marks
LG WM2301HW... | Answered on Jan 01, 2015
Yes, the motor has definitely burnt out causing an overload protection to switch off the electrical supply inside the machine.
LG WM2301HW... | Answered on Sep 28, 2014
LG WM2301HW Front Load Washer Logo
109 questions posted
Top LG Washing Machines Experts
Marvin
Marvin
jimorris77
Paul
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
LG Washing Machines
  • LG Washing Machines
Most Popular Question
grease like stains clothing after
  • Washing Machines
