20 Most Recent
Graco Digital Deluxe Imonitor With Vibration Questions & Answers
Hi, not sure if you can help me or not, but all of
I just fixed my unit that had this same problem. You have to re-pair the two units... Turn the parent unit off. Hold the "volume down" button while you turn the parent unit back on. The unit should beep and flash all volume lights. Release the volume button and the press again for ~2 seconds. The volume lights will light up and stay on. Next, turn the nursery unit off and then back on. This should re-pair the two. I hope it fixes your problem!
How do you remove canopy from graco sweetpeace
You need to remove the center of the part that connects to the chair. Use a thin screwdriver into the center and then pry each of the two tabs outward from the center. As you unhook it, you will be able to pry it out and then the attachment mechanism will pull off
How to remove seat wire, after putting it in wrong on the Graco uno2duo stroller?
This question was posted a long time ago, but no one answered it correctly. If you put the wire in backward, look on the end of where the wire was inserted. You made have to move the fabric to see it. There are holes. Use something to push in the metal piece that is showing as you pull out each side of the wire. I used a house key to push in the button while I removed the wire.
