20 Most Recent NetGear MBR624GU Wireless Router Questions & Answers
To log into a NETGEAR router:
  1. In your Web browser, navigate to the router login page. By default, one or all of the following URLs should work:
    • http://www.routerlogin.net or http://www.routerlogin.com
    • http://192.168.1.1 or http://192.168.0.1
    Note: You can sometimes find the login URL on a sticker on the bottom or back of the router.
  2. Enter the username (admin) and the password.
    • The default password is password, or for older routers, 1234.
    • If you have already changed the default password, use the password you assigned the router. Passwords are case sensitive.
    • If you have already changed the password and do not remember it, you have to reset the router to factory defaults in order to use the default password. Resetting a router to factory defaults erases all changes you have made to the router's configuration files.
NetGear MBR624GU... | Answered on May 30, 2014
If you're talking about wireless network key. you can access your netgear router page to view your wireless password and network settings.
to log in to the router:
1. connect the pc/laptop straight from the router using an ethernet cable.
2.Open a Web browser on your computer, and connect to the router by typing
http://192.168.0.1 or www.routerlogin.com in the address field of your browser.
3.When prompted, enter the router default user name of admin, and default password of password. The Router Status screen will come up.
4. Select Wireless Settings from the main menu to display the Wireless Settings screen.
from there you'll be able to view your network key.
Note: here's the download link for your netgear user manual.
ftp://downloads.netgear.com/files/MBR624GU_UM_27Mar09.pdf
Good luck,
Ryan
NetGear MBR624GU... | Answered on May 27, 2014
reset to factory default
press and hold reset button during the whole process and only release when completed.
1)press reset button 30 seconds
2)remove power cable 30 sec
3)plug in power cable 30 sec and then release.
You should no be set for 192.168.1.1
username admin
NetGear MBR624GU... | Answered on Apr 18, 2014
A wireless switch should be possible, try disabling its DHCP service and rely on your internet source for handing IPs to computers. this way your NetGear router is more of a switch than a router. of course, a wire connection between your Netgear router and the internet source is a must.
good luck,
NetGear MBR624GU... | Answered on Dec 28, 2011
Are you having a problem with your Netgear wireless router then -
To RESET the Netgear, power up the Netgear then press andhold the RESET button at the back of the router until all the LEDs flash. Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password You can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
NetGear MBR624GU... | Answered on Aug 25, 2011
http://192.168.0.1
The default PW = password You can now change the admin password and configure thewireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption or passphrase.
NetGear MBR624GU... | Answered on Jun 09, 2011
Sort of. It looks like Vodafone doesn't want people using routers with this device. You may be able to get around that if your router has the 'spoof mac address' functionality, but I imagine that's against Vodafone's Terms of Service.
NetGear MBR624GU... | Answered on Mar 05, 2011
You need to raise a case with the support section of your ISP, also make sure none of your neighbours are using your internet by password protecting the router login and using the built in WPA encryption.
I hope you found my reply helpful please ask if there is anything else.
regards
NetGear MBR624GU... | Answered on Feb 04, 2011
This is something you need to talk to LG about or look in the LG forums. It is not that the router is incompatible it is most likely the phone protocols. It may be worth talking to your network provider and raising it as an issue.
Have you tried it successfully with any other routers?
Good luck
You need to configure your router with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then set WAN settings as internet service provider settings enable DHCP. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
NetGear MBR624GU... | Answered on Feb 01, 2011
You may be trying to flash the NA (or US) firmware on a WW (worldwide) router or vice versa. This router is internationally crippled and Netgear will not do a thing about. I have the NA version and it doesn't connect to 3 Internet as the PDP type set to IP does not work. Firmware is poor and appears to based on ADSL model as there are still hidden bits relating to ADSL.
Anybody else...AVOID!
NetGear MBR624GU... | Answered on Dec 21, 2010
hi this does sound like it may be the channel, sometimes if you live in an area where the people are using the same channel normally defaulted to 1 this can cause allot of problems, also things like tv remote's , microwave ovens, anything that can transmit a wave signal can interfere with the wireless signal, i myself have allot of interference in my are so i changed to channel 3, this has helped allot and i do not get much if any interference now so really try experimenting with different channels to see how you get on......hope this helps
NetGear MBR624GU... | Answered on Dec 14, 2010
No, unless it support either a 3G USB or a SIM card.
NetGear MBR624GU... | Answered on Oct 19, 2010
it could be your email provider lagging and having technical issues. or maybe even doing system repairs and you just happen to be checking your email as the process was taking place.
NetGear MBR624GU... | Answered on Apr 18, 2010
Try to change the ports to 8081.
NetGear MBR624GU... | Answered on Mar 02, 2010
NetGear MBR624GU Wireless Router Logo
35 questions posted
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • NetGear Computers & Internet
Most Popular Question
manually set up router from netgear
  • Computers & Internet
