20 Most Recent Dell Inspiron B120 B130 1300 / Latitude 120L Motherboard - RJ273 - GG0 Questions & Answers
please enter wireless ip adress for internet company
Dell Inspiron... | Answered on Apr 18, 2012
Any laptop should run with a cord (that is functioning properly) whether there is a battery installed or not. Have you checked the charger to verify that it is putting out the proper amperage?
Dell Inspiron... | Answered on Nov 23, 2010
If your notebook appears to boot up and the hard disk LED flashes, you could have a back light problem which can be caused by a faulty inverter or a faulty CCFL lamp. Please click on this link to determine the fault and fix :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Dell Inspiron... | Answered on Nov 20, 2010
It uses the integrated 440x 10/100 chip, you have mentioned 4 different laptops here, all use the same chipset, so the drivers should be the same.
Try here http://support.euro.dell.com/support/downloads/driverslist.aspx?c=uk&cs=ukdhs1&l=en&s=dhs&os=WW1&osl=en&SystemID=LATITUDE%20120L&catid=-1&impid=-1
Dell Inspiron... | Answered on Sep 03, 2010
Try a repair installation.
Is this an illegal copy? If it is, it may have virus or malware problems.
Dell Inspiron... | Answered on Jul 22, 2010
Hi there, click on the link below to download the drivers
ftp://ftp.us.dell.com/network/R151519.EXE
Dell Inspiron... | Answered on Mar 07, 2010
Could it be overheating, and automatically shutting-down, to avoid damage?
Shut it down.
Disconnect the AC power.
Remove the battery.
Purchase a can of compressed air, and give your computer a "blow-job", shooting compressed air into every orifice, to remove all the dust that could be acting like a layer of "insulation", preventing your computer from cooling itself.
Dell Inspiron... | Answered on Jan 04, 2010
After you format the drive you need to go to DOS and load DOS with CDROM support, then launch Windows through the command prompt
D:\I836\winnt.exe
the D may be another drive letter, but that should start your install.
Good Luck
Mark
Dell Inspiron... | Answered on Dec 28, 2009
It is hard from your post to de-cipher your actual problem or request but I will do my best
Internal wireless adapters on laptops and notebooks do not connect to external antenna. They use their own and altering them could cause damage to the adapter or worse.
If you have had your laptop open and been inside t then you really should have noted the path of the wires down before disconnection
You could get the service manual from the support section on the dell website which may help you.
OR
If you mean that you cannot connect to your router then you should check that the channel on your router does not conflict with anyone else nearby and that if it has an option for auto channel selection that you enable it.
Check that there are no other wireless devices nearby telephones, baby alarms, etc etc. Check also that there are not too many obstructions between your laptop and the router esp. large metal ones.
You might want to try moving the router to a better location too.
If this information was of use then please click below
Dell Inspiron... | Answered on Aug 18, 2009
Hi first my question is if the wireless setting is secured. If it is you have to enter the wep key or passphrase to the laptop. if you don't know what is the wep or passphase you may open the web browser and enter this ip address 192.168.1.1 and the user id is admin but this time you have to find out the password. wants that you get in click the wireless security tab and the info is there. Wants that you have enter this info to your new laptop this is will work. Also you may do is right click the network connection, click the property. click internet protocol (TCP/IP) click property and make sure that the setting is on obtain an ip address automatic then click close. I hope this info will help you solve the problem.
Dell Inspiron... | Answered on Aug 17, 2009
light should be green instead of orange. check in your device manager to make sure the driver is installed for the ethernet adapter, if it is then you know the motherboard is bad cause the ethernet adapter is connected to the motherboard.
If the driver for the ethernet adapter is not installed then go to support.dell.com and from there go into the drivers section, type in your model and then download the driver for your laptop and install it and then see if you can connect. If you do this and you still can't connect then that still means the ethernet adapter is bad and the motherboard would still have to be replaced.
Dell Inspiron... | Answered on Aug 09, 2009
there is a lot of beepings errors. tell me how many beeps you heard while booting? and what indicating of lights in your laptop?
It should run with the bad battery in if AC power is connected. Then just run the restore cd. Good Luck
Dell Inspiron... | Answered on Jul 29, 2009
VGA chip burned to a crisp, might be able to reflow it see youtube how! If you open your laptop see the cooling fan its probably blocked by dust hairs and dna
Dell Computers &... | Answered 18 hours ago
If you've reloaded or upgraded Windows, you might not actually have the correct video driver installed (the display will work with the generic drivers in Windows). Go to www.dell.com, click on Support and put your Service Tag in. That exactly identifies the hardware. Look for Downloads and/or Drivers, then scroll down to find the Video Driver. They're easy to download and install.
Dell Computers &... | Answered 23 hours ago
Read the manual that came with the computer software.
Dell Computers &... | Answered Yesterday
To speak Dell technical support representative dial +1-800-204-4427 USA , 1800954262 AUS, +44 (800) 046-5216 (UK)Am to 6 Am, Pacific Time, Monday through Friday. To speak Live Customer Support provide 24*7 18002044427 USA.UK.AUS.CANADA Call US :+1-800-204-4427 UK : +44-8000465216 AUS :+61-1800954262 Hotmail Support Number 1-800-204-4427 USA.UK.AUS.CANADA Dell Technical Support Phone Number 1 800 204 4427 USA Canada
Dell Computers &... | Answered 2 days ago
Hello James Parker,
Don't take much stress about it because it's very easy to contact Dell experts. You just need to dial toll-free dell technical support phone number +1-855-676-2448 (USA, Canada) than Dell experts will also give you complete solution at same time. You can call anytime 24/7. For more info visit the website:
Dell Customer Service Number 1 855 676 2448
Dell Inspiron B120 B130 1300 / Latitude 120L Motherboard - RJ273 - GG0  Logo
Popular Tags
19 questions posted
Alun Cox
View Most Popular
  • Dell Computers & Internet
Most Popular Question
type network controller computer use
  • Computers & Internet
