20 Most Recent
LG GSA H62N Super-Multi - Disk drive - DVD RW / DVD-RAM - 18x/18x/12x - Serial ATA - interna... Burner Questions & Answers
Keeps telling me to lnsert
CLEAN THE DISK WITH WATER, THEN WIPE , THEN ALLOW TO DRY COMPLETELY . THEN INSERT AND TRY. SHOULD WORK.
The DVD/CD Rom Icon has
You will need to re-install the driver. Right click the device in device manager and select properties. Navigate to the driver section and uninstall all existing drivers. (It may *not* give you the option to do that, depending on how corrupted the driver is, but it should.)
Reboot the PC.
Upon reboot, Windows should find the new device and install generic drivers. It will probably ask you to reboot a second time.
I own LG super multi
you might try updating the drivers .you also might try running a disk cleaner in it it might just be dirty. good luck.
My dvd-RW wont read any of my dvd's except plain
set it up on a seperate IDE Channel, or change from master to slave. Or Vice-Versa.
Secondly you could try re-installing windows 2000, this should repair any corrupt or missing drivers.
Finally see the manufacturers website, to see if any firmware upgrades are available.
Or else try this
Start Registry Editor (Start, Run and type in regedit then click)
Find "UpperFilters" and "LowerFilters" (and "UpperFilters.bak" "LowerFilters.bak", if they exist) value under the following key in the registry, and delete it:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Hope This helps...
thank u
rate me!!!
What normally burns out the LG Hi-Fi Amplifier?
Full 'make model (what it is)' in all questions please, first 3 words.
Capacitors can split or bulge, resistors can burn,, the transformer can fail internally..
Take it for repair unless you have the thousands of dollars of test equipment and have do the 2 year electronic course.
What does 9 red flashes mean on LG multi V LMU540HV
A communication error has occurred between the outdoor and indoor units. Faulty wiring or a malfunctioning control unit may be responsible. Contact LG customer service for assistance. Their number is 1 800 243 0000.
