20 Most Recent AudioBahn A2002T Car Audio Amplifier Questions & Answers
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Sounds like you are overloading the amp. Please check speakers impedance. .A thumbs up would be greatly appreciated if this answer is helpful to you
AudioBahn A2002T... | Answered on Feb 03, 2015
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty .
Either blown subs, or bad amp.. Disconnect the subs, and try turning the amp on, if the amp is still in protect then your amp is bad, if the protect light goes off, then your subs are bad, or possibly wired at to low of an impedance, but I don't think that will trigger the protect on an Audiobahn amp.
You blew the audio outputs on the board. If its under warranty you can try to get it serviced or swapped out where you bought it.
AudioBahn A2002T... | Answered on Jun 04, 2011
have you checked all the fuses and wires?
AudioBahn A2002T... | Answered on Oct 05, 2010
you can go to crutchfield.com and they will show you step by step but all you need is a long enough power wire from your battery but make sure you have a inline fuse about 12" off the battery. run a remote wire off of your head unit to the back of car, make sure you have a good ground bout 3' wire that's about it then run your wires for your speakers
AudioBahn A2002T... | Answered on May 11, 2010
audiobahn.com you can download the manual under tech suport
you can use your rear speakers get a wire to run from the speaker to the high input in the amplifier the then hook up the power to the am and find a good ground then need a a wire that ges power only when the car is turned on so find the accessory wire in the back of te stereo it is allways yelow cut in to it and stick your amps remote then lower all of your bass and treble then slowwly in crease it to match you rear speakers with your front and your subs
AudioBahn A2002T... | Answered on Oct 28, 2009
You have a Direct Short in the System Between the Head Unit and the Amp. Check the Ground on the Amp and then Check all the Wires behind the Stereo and the Common Ground There. You could even have a Spot in the New RCA Cables that is Touching Metal Somewhere. Please Rate My Response! Thanks!
AudioBahn A2002T... | Answered on Sep 01, 2009
Hello sting_ya_sco,
The ACAP501Q has 2 sets of of RCA jacks. The first set is input and 2nd preamp outputs. The jacks are factory covered with plastic protectors. Just pull the protectors off and plug in the cables.
Hope this helps.
AudioBahn A2002T... | Answered on Jul 25, 2009
Just go with the lowest amp draw fan, 12 volt that they make, and that should work.
AudioBahn A2002T... | Answered on Jul 06, 2009
that meands u have constant power try putting a toggle switch on the remote wire
AudioBahn A2002T... | Answered on Jul 05, 2009
it shows either power to amp is on or protection mode
AudioBahn A2002T... | Answered on Jun 25, 2009
could be that you dont have the right wiring too small will make the amp work harder to draw more power makes the amp hotter
hope i was help!
AudioBahn A2002T... | Answered on Mar 22, 2009
Yes, and would imply that the amp is powered up all the time.
You should correctly wire your system by
1.Connecting the constant 12vdc input wire to a constant 12vdc source to power the in-dash head units memory.
2.Connecting the switched 12vdc input wire to a switched 12vdc source to power the head units primary functions.
3.Connecting the remote output wire (typically a blue wire) from the in-dash head unit to the correct terminal on the amp, so the amp will only power up when the head unit is on.
4 Remember to run the signal (speaker) wires in a chase separated from the amps power wires, so as to avoid a buzzing noise in the speakers.
5. Always use an in-line fuse on the amp and the head units main power wires.
Note: A properly powered amp will produce a better sound quality then if it were under powered, so be sure to use the proper wire gauge as your amps power supply.
Good luck
Aduz
You should never disconnect the ground from the amp when it has B+ and remote voltage applied. This will cause damage to the head unit ith some amplifiers.
Does the protection light come on with the ground wire connected?
AudioBahn A2002T... | Answered on Feb 13, 2008
Start with a quick once over of the user manual, from what i can tell the site requires a quick membership (free) to look at the manual.
You may also be able to print out any pages you need to help you troubleshoot your problem.
This should help you narrow down if you have anything connected wrong.
http://caraudio.manualsonline.com/manuals/mfg/audiobahn/audiobahn_a2002t_a2002t.html
AudioBahn A2002T... | Answered on Jan 24, 2008
AudioBahn A2002T Car Audio Amplifier Logo
Popular Tags
21 questions posted
Top AudioBahn Car Audio & Video Experts
Dalynn Turner
Mike Duncan
Mike Duncan
Professor_V
Professor_V
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • AudioBahn Car Audio & Video
Most Popular Question
audiobahn a8002v
  • Car Audio & Video
