20 Most Recent
Gateway FX6800-05 PC Desktop Questions & Answers
How do Imanually ejecting a disc from a gateway
There should be a small round hole on the door near the eject button.
Using a straightened heavy paper-clip, insert straight into the hole.
There is a lever inside that you will feel, press in until the door comes partly open.
Then you can pull the door to access the disk.
Restore gateway FX to factory settings
If your restore partition is intact, you can press F11 at boot, and follow the on-screen instructions to do a factory restore. Be sure to backup your data first, as it will be deleted in a Factory Restore.
Cd driver not opening
Open a paper clip and see if you can find a tiny hole in the front of the cd drive. Push the sraightened out paper clip into the hole and the drive should open without power on the computer. The hole on my dvd plyer is just above the switch which opens and closes the dvd drive. If the paper clip is too big you may have to go to a pc shop and buy a pin which comes with most new dvd players. If the owner of the shop is a nice person they may give you a pin and explain more.
Power suppy connections to computer
What is the question? When hooking up a power supply, there are only 2 plugs to hook up and there are only 2 places on the motherboard where they fit.
I have a Gateway LP2417 monitor and there's No sound.Hoe do I fix it,so I can hear the video that is playing?
This monitor may not have built-in speakers. It may have supported Gateway's monitor mounted sound bar. That sound bar connected to the 3.5 mm audio out on a computer and a DIN port on the monitor.
The simplest solution is to connect your source to appropriate speakers. Depending on your audio setup, you could connect the video source to a receiver with HDMI IN and HDMI Out (ARC), computer speakers or an audio extractor. (If you are using an HDMI cable between the Gateway LP2417 and a computer, you may need to reset the audio output to use basic computer speakers (3.5mm jack).) VGA and DVI connections don't support audio so I assume you are using the HDMI port.
I hope this helps.
1/18/2024 10:32:24 PM •
Gateway...
Answered
on Jan 18, 2024
