20 Most Recent
Dell Vostro 220 PC Desktop Questions & Answers
Factory reset
Power computer off, power on, keep tapping F8, repair computer and select recovery options and follow onscreen prompts
There is a message in my computer,
if you want to know what this is the error code is related toclick start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
or click start type in event viewer press ENTER
you might be able work your way through the problem
if you need more help with this post a reply with the error message details
hope it helps
Message: Virtual Memory is too low. The pc is too slow to work.
You may need more RAM. Right click My Computer > General.Or, open Control Panel > System. RAM will be noted. You can run / see Windows Experience in Win 7. Your score is based on lowest score. Check RAM score.Win 7 works best with at least 2GB of RAMAnother trick is to disable startup programs from loading in the first place. Go to Start > Run (search in Win 7) and type MSConfig > Startup tab and uncheck anything that you don't want Windows to load automatically.
BUGCODE USB DRIVER
Computer needs cleaning, the CPU heat sink might be full of dirt, brush it off. Remove and clean the memory contacts too... then insert it back. You need to be careful with the parts inside these are delicate parts.
How do I reset my
if you forgot the password for tyour winows log in theres no real easy way to change the password. one way is to get a password recovery tool. you have to be carefull because there is a alot of scams out here. in my experience heres the top five i suggest
- Stellar Phoenix Password Recovery - Simple startup utility resets a forgotten admin or users' password using a familiar Windows-like program interface instead of command-line.
- Password Kit - Top rated version of Passware's Password recovery app, supports Windows Vista and RAID/SCSI/SATA drives.
- Petter Nordahl-Hagen's Offline NT Password & Registry Editor - A great boot CD/Floppy that can reset the local administrator's password.
- Openwall's John the Ripper - Good boot floppy with cracking capabilities.
- EBCD - Emergency Boot CD - Bootable CD, intended for system recovery in the case of software or hardware faults
- the next step i could recommend if you do not want to do this is to try a system restore. if you have the system cds that come with the computer you can put them in and when starting up computer you should see setup or system restore in bottom right or left corner. it will say hit f12 or f2 you are going to want to go into there and boot from cd. once you boot from c you will be able to do the system restore and set computer back to factory defaults.
Have a Dell Vostro 220a
If the drive was working before normally then the lens of the drive has started to Mal-function. please contact the manufacturer if the product still has warranty.
Bluetooth & sound
Generally, connecting phones via bluetooth to a laptop just allows for file transfer between the two devices. It is not to input sound from the phone through the speakers of the laptop. You would need a bluetooth audio device for that such as bluetooth speakers or headphones
Code 10 is not starting
This error is basically saying that Windows, for one reason or another, cannot communicate properly with one of your programs. This communication problem is usually caused by out-of-date, missing or corrupt device drivers. ... Select Start > All Programs > Windows Update.
This copy of windows is not genuine
i used to get that also, I wrote down windows numbers from windows sticker on the side of machine, (needed magnifying glass) and went online to windows verify, after they scan it, it came out good
HOWCAN FIND MACADRESS WIFI LAPTOP VOSTRO1500?
Open a command prompt ( Windows key + R to open Run box, then cmd), and type
ipconfig /all
and look for the wifi adapter. The entry labelled "Physical Address" is the MAC address. It will look something like 84-3A-4B-C8-E9-B7
(Your router might want it entered in the format 84:3A:4B:C8:E9:B7)
Cpu overheating
The cooling fins on the processor chip are plugged with dust. The fan may not be turning fast enough. If that's the case you'll need to replace the cooling fan
