20 Most Recent Pix FUJIFILM Fine F200EXR Digital Camera Questions & Answers
My digital camera's lens were dislocated.
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
11/18/2012 5:05:45 PM • Pix FUJIFILM... • Answered on Nov 18, 2012
How do I activate my 6 months free warranty.
http://www.fujifilmusa.com/products/digital_cameras/product_registration/pixrx/index.do
5/15/2010 6:33:12 PM • Pix FUJIFILM... • Answered on May 15, 2010
After downloading my pics to my Mac (snow
Are you right-clicking the icon and choosing "eject"? You could also just drag and drop it in the trash...this is the same as eject.
12/28/2009 10:04:20 PM • Pix FUJIFILM... • Answered on Dec 28, 2009
The message is <zoom error> and I can'T TAKE ANY PICTURE
I have simply swiched off my camera, and I left it off for quite 30 minutes.
When I have turned iy on, fhe camera worked/
Like my computes sometimes does!
8/23/2009 5:12:38 PM • Pix FUJIFILM... • Answered on Aug 23, 2009
I never got a manual for my s 5200 fuji fine pix.
M-manuel, you set up all of the functions, difficult as the camera will not give you any help A-apeture priorities, you tell the camera the apeture you want to use, the ISO you want,the white balance you want the exposure level you want, and it adjusts the shutter speed to compensate S-shutter priorities, just like apeture priorities except the camera adjusts the apeture fou you instead of the shutter speed P-program mode, lets you tell the camera how bright or dark you want the picture to be, and it adjusts everything else
Here is a link to a website that has an instruction manual
7/28/2009 3:36:07 PM • Pix FUJIFILM... • Answered on Jul 28, 2009
Cool Pix Nikon, 510. - memory crd does not attach to stay in
There are some very small parts that hold that card in when it is inserted. Nikon seems to have issues with them. There are videos on how to repair the camera on Youtube but they are not for the faint of heart.
11/1/2021 2:38:35 PM • Pix Cameras • Answered on Nov 01, 2021
Black & white setting on Cool Pix 100 where do i find it. Eileen
This will probably be a menu setting - information in the manual should help you locate this.
7/1/2019 10:36:28 PM • Pix Cameras • Answered on Jul 01, 2019
The cool pix s3600 camera froze open. Cannot turn off camera.How do I fix this.
Remove the battery
3/18/2019 10:28:13 AM • Pix Cameras • Answered on Mar 18, 2019
Cool pix aw 120 focus not fine tuning can see it focus the drift off
Are you using half pressure to maintain focus ?
12/10/2017 11:52:11 AM • Pix Cameras • Answered on Dec 10, 2017
AMANO PIX 55 WHY WONT IT PRINT TIME IT ONLY PRINTS DATE
MAYBE IT DOESN'T LIKE BEING SHOUTED AT - AND NEITHER DO WE. If you look in the manual, and correlate the instructions contained therein with the myriad menu settings controlling every aspect of the camera's function, I'm sure you'll be able to figure it out, in time.
12/4/2017 4:48:31 PM • Pix Cameras • Answered on Dec 04, 2017
Where can I find a alatel pix unite case cover or #A466BG
Try a cell phone store or eBay.
12/31/2016 9:17:31 PM • Pix Cameras • Answered on Dec 31, 2016
0answers
My cool pix s70 camera Lens is not working right
Try this : Lens Error Fixya
12/1/2016 7:41:06 PM • Pix Cameras • Answered on Dec 01, 2016
Pix FUJIFILM Fine F200EXR Digital Camera Logo
Popular Tags
5 questions posted
Top Pix Cameras Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Pix Camera Expert? Answer questions, earn points and help others
View Most Popular
Pix Cameras
  • Pix Cameras
Most Popular Question
activate 6 months free warranty
  • Cameras
