The product arrived with an instruction manual. I followed the instructions, installed the included software, and then was unable to get the product to work as my PC (Windows 7) did not seem to recognize the device. I tried several USB ports to no avail. I emailed the seller and promptly received an email with different instructions. Although the software version on the installation CD was different from that referenced in the instructions, I was able to install and finally got the device to work as needed. The problem is that there are two programs on the installation CD and one (cassettemate) appears not to function, while the other (audacity) is what is needed. This is not indicated in the instructions that come with the device.Close cassette mate window and open audacity press play in the cassette player and press recording button in audacity program.
the product arrived with an instruction manual. I followed the instructions, installed the included software, and then was unable to get the product to work as my PC (Windows 7) did not seem to recognize the device. I tried several USB ports to no avail. I emailed the seller and promptly received an email with different instructions. Although the software version on the installation CD was different from that referenced in the instructions, I was able to install and finally got the device to work as needed. The problem is that there are two programs on the installation CD and one (cassettemate) appears not to function, while the other (audacity) is what is needed. This is not indicated in the instructions that come with the device.
Unfortunately, no one knows or is telling. Companies rarely state power in RMS because Peak Power is a much more impressive. 1000 watt amp, 200 watts RMS x 2 channels at 8 ohms. Look for a sticker on the unit.
https://www.google.com/search?q=Xplore+Amp+5553
'year make model' of the vehicle is needed in questions like this please?
Modern vehicle radios are controlled by the Body control Module (BCM) and are used for broadcasting warning beeps and indicator clickers. The beeps an be as innocuous as "do you know your radio is still on"? It can also be caused by your cellphone pinging local transmitters and receiving a confirmation back, or checking in for emails.
JustAnswerhttps://www.justanswer.com > Mercedes Repair
Aug 26, 2010 - What causes a beeping noise to come over the radio speakers? How can it be made to stop? - Answered by a verified Mercedes Mechanic.
1 answer · Top answer: Chat Conversation Started Pete : Hello,I will be glad to try and assist you with this,Welcome ...
Missing: periodic ' Show results with: periodic
iFixithttps://www.ifixit.com > Answers > View > Why+is+m...
Apr 6, 2019 - My speaker has suddenly began making a single sound every few seconds which sounds like a single busy signal on a phone. I have read the manual, ...
11 answers · Top answer: It's low on battery. Plug it in!
Answershttps://www.answers.com > Auto > Auto Parts
Oct 26, 2022 - Press the AS button and hold depressed while turning the radio on. (after 3 secs you should hear a beep. Release the AS button. The display ...
