20 Most Recent ASUS AiLifestyle P5KC Motherboard Questions & Answers
http://www.asus.com/Motherboards/P5KC/
ASUS AiLifestyle... | Answered on May 18, 2014
You can find the BIOS updates right here:
http://www.asus.com/product.aspx?P_ID=fFZ8oUIGmLpwNMjj
Go to download. select "others" in "operating systems". Go to BIOS, expand that. The first one is the last update.
ASUS AiLifestyle... | Answered on Mar 04, 2011
Ir a:
http://support.asus.com/download/download.aspx?modelname=P5KC&SLanguage=es-ar
A continuación, seleccione su OS.
ASUS AiLifestyle... | Answered on Jul 20, 2010
Try reflashing your bios with latest version check usb is enabled in BIOS if your using a usb keyboard otherwise maybe a dodgy board. Good luck
ASUS AiLifestyle... | Answered on Dec 24, 2009
If your WD id IDE
There is 2 ports for IDE master and slave you can try to swap to see it can recognize providing you set the correct jumper for M or S.
If your WD is SATA
There is more than one of SATA ports you can try to connect for every boot.
If it doesn't recognize, either bad board or bad WD
ASUS AiLifestyle... | Answered on Oct 22, 2009
did this PC come as total build up PC from ASUS
or just a mobo, DIY PC????? or V-series sold at bare bones??????
why do this , if PC runs for year with present bios why risk bricking a good PC, (sure FUD fear endless)
that mobo is old. they do not update old mobo back to 1995
only the most new are supported like that.
there are like 10,000 models now from them.
imagine cost of doing that many updates. ? yah bankruptcy.
Im a ASUS long time users, from 1995 to now,
know them well.
The facts are like this,
first there are P5 mobo and huge numbers of sub models of just P5 prefix. end HW version # too
the fact is you must read the box to get all the facts but is lost, SKU.
so we then read the MOBO silk screen to see what is this mobo
exactly if you get it wrong you brick the PC and is so easy to do.
there new web site stinks they make it very hard to see all class motherboards and once, P5
unlike the old site that was wonderful..
and they ended the forum too, a horrid IDEA that.
it came with
at best core2 pentium
here is the problem it is your model is wrong.
this is there crummy javascript running, that is hyper active and very hard to uses. but I captured it just for you.
it is 5 PCs sold then, in case from them. V and T series.
the last one (wild guess on model) runs bios 2008 (and forever )
Version 0401 2008/03/24651.3 KBytes 0401 BIOS
Fix CPU Vcore isn't correct with E4400 Series CPU
ASUS Computers &... | Answered Yesterday
down load what you skipped what.
your photos.?
or some kind of application software related to photos. etc??????
i
old pc.? 6 years old 2012 made.
not too old but most PCs from that era to now make this 1000x hard to do.... new laws. did that.
the only cure is to ask asus.com for help.
there is no other way. (besides guessing lost pw)
BIOS, lost PW.
Asus, no longer runs great forum. there. (only gamers)
so they deleted there great forum.
asus.com is all there is.
this is all they have now (lame)
https://www.asus.com/us/supportonly/K55N/HelpDesk/
then the issues of fingerprint reader. too.
if that is enabled, it is even more hard to fix.
you need to call them , and ask. see contacts under support.
this is also now a topic bound by new laws. USA and EU.
backdoor Passwords are not legal now.
old PCs had jumper inside to reset this and are NOW GONE.
BY DESIGN.
(BIOS history) old to new PCs. simple
1: pull coin cell out, (all batteries and power pack) now reset.
2: find mobo jumper clrPW, jumper it and bam reset.
3: then PW stored in EEPROM device, NO JOY there. very hard.
4: now TPM and UEFI laws for PCs, and NO JOY. win8 up. 2013 up.
That is the history of PW resets, each era go harder.
and just before windows 8 was release SUPER HARD super SECURE PC now. best is not use the PW at all, ok.
if you have BIOS admin PW you can reset any BIOS USER PW.
if the hDD password is set, your data is DOOMEd.
we can talk PW all day long, but just don't use
BIOS PW at all, unless work for CIA/DOD or NSA.
ok>/???
why, tell why first. context matters, for sure.
but you can remove the coin cell on any PC made (some tiny notepads excepted, have none see why below)
that resets all PCs made, and will not erase passwords.
PW are not STORED THERE, NVRAM CMOS.
ever heard of asus.com?
there huge web site, support??
the real name is
ASUS VivoBook X540LA
asus has no service manual; only user man. and has no such topic in the users manual
as a rule (thin notebooks)
if the huge battery on that just snaps off the bottom in 5 seconds
yours don't.
it's no longer there, that means it is now deep inside and thin.
and that means most PCs like that , have no coin cell.
that means you must unplug the inside flat black battery
push power for 10 seconds (button) release then wait say 1/2 hour the put the battery back in.
now the NVRAM CMOS is reset.
does that answers your question?
here is your big battery, remove this , per above.
and if BIOS NVRAM CMOS resets then good.
if NOT there is a coin cell hidden deep in side, fact is.
540-1v11prkoqtrvvozsyhes0xol-5-0.jpg the joy of thin notebooks 101
ive no idea what OS is running there and is OS question.
why not connect mouse, be 10x more easy that way.(click and drag)
i typed tp140 at asus.com got nothing.
even 140 gets me zero
what is this PC.
no vivobook has that number 140
but connect a mouse and drag the files.
or post your service tag for this laptop? or what ever it is, unstated by you. all we know is it is a COMPUTER.
ask them, most PCs it is an option now.
F8V (and sub numbers) tell you what features they have.
is this a pre -sales question (no), unstated. and matters.
or buying used PCs. ? (I BET YES)
try reading here first.
https://www.asus.com/supportonly/F8V/HelpDesk_Manual/
that designed it, built it and sell it, and support it.
ask them is best. (vast models and sub models exit) !!!
even different by COUNTRY we are USA are yOU>?
the build PC for a country, (laws vary)
im reading now for you and PC is 1 decade old.(English only)
and touch WORD is not in the books.
ASUS Computers &... | Answered 2 days ago
ok this is so simple.
first off the router has ethernet,
and you can run 10 Access points or more in home..
off that 1 port. (router to AP1, then to AP2, and to AP3
all wired, then each with its own SSID. that is how I do it
and gains max range doing so.
if you like magic, get a MESH AP. (but is expensive)
and point 2, all AP even modem wifi or router wifi can be turned off easy, the manual is free to read, and the box to check is called
disable. wifi. for sure.
if you cant tune off wifi in the ISP modem and they will not help you then just leave it alone, ignore it
and setup an AP with its own SSID.
even use different channels, too. for sure.
well if you don' t own a printer?
take The PDF file to any copycenter and tell them to print it.
why do you need paper? just keep the PDF on the desktop and you have it there forever.. no need for paper ever. now.
paper really is dead. ( keep my PDF's on a backup media)
have them back 20 years no need for paper.
ask ASUS.com this.
no PC stated at all. so is IMPOSSIBLE question.
only the OEM can unlock it.
if only windows login locked, ask Microsoft.com this.
****WARNING THIS POST AND ANY LIKE IT ARE PURE SPAM**** IF YOU CALL ANY NUMBER YOU SEE HERE YOU ARE DOOMED TO LOSE YOUR MONEY AND HAVE YOUR CREDIT INFORMATION STOLEN FROM YOU HEARD OF IDENTITY THEFT??? DONT CALL THEM. THEY ARE THIEVES AND BEGGARS HERE AT FIXYA...;;;PO0
ASUS Computers &... | Answered on Sep 13, 2019
****WARNING THIS POST AND ANY LIKE IT ARE PURE SPAM**** IF YOU CALL ANY NUMBER YOU SEE HERE YOU ARE DOOMED TO LOSE YOUR MONEY AND HAVE YOUR CREDIT INFORMATION STOLEN FROM YOU HEARD OF IDENTITY THEFT??? DONT CALL THEM. THEY ARE THIEVES AND BEGGARS HERE AT FIXYA...7776009
ASUS AiLifestyle P5KC  Motherboard Logo
Popular Tags
7 questions posted
Popular Products
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Computers & Internet
Most Popular Question
takoue yves
  • Computers & Internet
