20 Most Recent
ATI RADEON HD 3650, PCI Express Video Card Questions & Answers
Need driver for video card
Hi. Follow this step to download the driver for your video card.
1. Go to this website
http://support.amd.com/us/gpudownload/Pages/index.aspx
2. on the step 1: Choose Desktop Graphics
step 2: Radeon HD Series
step 3: Radeon HD 3xxx Series PCIe
step 4: your Operating System currently installed on your desktop (e.g. XP, Vista or Windows 7)
3. Download the driver and install it on your desktop
Hi I have an ATI
Go into Control Panel and choose the Display option in XP or Personalization option in Vista. Find Display settings.
Then check the Extend the desktop onto this monitor box to activate the 2nd monitor.
I recentl reformatted my computer and although I
And you re-checked your BIOS and it has the right 512mb and PCI adapter setting. You also might try in the hardware device manager since I know the software usually does it. You may be stuck between the 2 videos adapters your using too. Make sure the BIOS is set for the card's PCI. does it have a little e' to it.
Ati HD 3650 No Signal
1st. Is it a new install?
If not, then check to make sure your bios on your motherboard is set up to display from your pcie slot and not your integrated graphics if applicable. Also, if your card has a 6pin power plug make sure you have it plugged in.
Also, if you had a different card installed prior, make sure you uninstall all video drivers prior to installing the new one.
Visual errors occur and the game is unstable is
I found the driver for your card, though you may want to punch in the specifications yourself.
Go to the link and look on the top right. You'll see "Download Drivers".
This all depends what game you are playing and what system you're running on.
With what little information I had, this was the best I could do.
In my opinion, if you're trying to play a recent game, you'd have to bring the visual settings all the way down in the game.
If this wasn't helpful, post more information please.
Let me know.
My HD 4850 fan is
Your heatsink fan on the graphic card is failing and the motor is going down hill, now saying it has completly stopped..,.. that means the fan motor is done for and need to be replaced to avoid further damage to your graphic card. Would reccommend you not using your graphic card until a new heatsink fan is replaced otherwise you can fry your GPU and suffer a complete loss.
My graphics card will not
How did you get your drivers and graphics? Did you install the whole package? What is the Asus model #? How much Ram do you have? I'm going to do a little research but let me know what you have.
Dave
HIS radeon HD 6750
Are you certain that your mainboard is PCIE 2.1 and not PCIE 2.0?
PCIE 2.1 cards like yours will not work on a 2.0 mainboard (2.0 cards will work on a 2.1 board, however) If this is the case, you will need to get a compatible card.If this isn't the case, have you tried this card in a different PC? It could also be that the card has a problem.The last possibility is that there are power issues. A couple of possibilities:
- An external power connector (6-pin PCIE direct power to the video card) is unplugged. Check and re-test.
- Your power supply (PSU) doesn't provide enough power to your graphics card & the rest of your system. Check your PSU's specs against the specs for your card. HIS recommends a minimum 450W PSU, and I would recommend a good quality Antec, Corsair, or PC Power and Cooling or Cooler Master product in the 500W range for this card.
- You got a bad card, or else it shorted out, etc. during setup or installation.
Gigabyte vga card d33006
your card is the gigabyte GV-RX195P256D-RH and you can download the drivers from here https://www.gigabyte.com/us/Graphics-Card/GV-RX195P256D-RH#support-dl-driver-vgadriver
