SRU4050 codes
It seems that there is no setup code for this Aiwa device, with this Philips universal remote control. Anyway, try a code search method. If there is a pretested code, this process will help you.1. Manually turn on the device (TV, VCR, etc.) to becontrolled.2. Press and hold the SETUP button until the redindicator stays on, then release the SETUP button.3. Press and quickly release the desired mode button(TV, VCR, etc.). The red indicator blinks off once.4. Press the CHANNEL UP button repeatedly (up to300 times) until the device to be controlled changeschannel. The red indicator blinks off with eachbutton press. If you accidentally overshoot thecode required, press the CHANNEL DOWN buttonto backtrack through the library until the devicechanges channel. Pressing CHANNEL UP changesdirection to forward again.5. Press and release MUTE to install the code.Most users will store VCR codes under the VCR button,Cable codes under CABLE, etc. If (for example) youwant to store a VCR code under CABLE, first follow theprocedure for Direct Code Entry (previous page) andpress CABLE in step 2 of Direct Code Entry, then enterANY VCR code in step 3 of Direct Code Entry. Thenfollow the steps above for Code Search (or BrandSearch, below). Note: If the device does not have aCHANNEL UP button, use PLAY (VCR only) orPOWER instead. Code Search starts from the currentlystored 4 digit number under that mode.Code search by Brand.Lets you search for a code for a specific Brand withinthe Code Library for a particular manufacturer.1. Turn on the device (TV, VCR, etc.) to be controlled.2. Press and hold the SETUP button until the redindicator remains on, then release SETUP button.3. Press and quickly release the desired mode button(TV, VCR, etc.). The red indicator blinks off once.4. Press and release the numeric button (0-9)corresponding to desired Manufacturer (see table oncode list sheet). The red indicator blinks off once.Note, pressing "0" performs a full library search sameas normal Code Search Method on previous page.5. Press the CHANNEL UP button ((orPOWER orPLAY (VCR only)) repeatedly until the device to becontrolled changes channel. The red indicator blinksoff with each button press. If you accidentallyovershoot the code required, press the CHANNELDOWN button to backtrack through the library untilthe device changes channel. Pressing CHANNELUP changes direction to forward again.6. Press and release MUTE to install the code.Brand Search Method entry is now complete.Note: When all codes under a Brand have been searchedthe red indicator flashes rapidly for 3 seconds.
