Troubleshooting & Support for
4,128 people viewed this product
Check the Output specifications on the transformer in question and note the power output or 'Se...
Hope this helps you out. Digital Security Controls 3301 Langstaff Rd Concord, Ontario, Canada PH: 905...
The PTD1640U output is 16 volts AC (alternating current) so there is no polarity to the wires. You can...
Since you do not have the code you have 3 basic options:Call your local DSC dealer/installer and hav...
has to be the four digit MASTER code and military time. sometimes have to do twice. For instance. *61...
You can use any standard 16v 40va transformer, either of the Plug in or wire in variety
If it is the PIR that uses 4 AA batteries, they are behind the circuit board. Grasp the sides of the boa...
Generally entering your security code will turn it off for 4 hours, but it will reactivate per...
You don't mention what type of sensor. I assume it is a motion detector. Before replacing I would str...
First of all go to your security box.Now you will have to find where all the sensors conect to the pan...
Here's a video kress riko suggested as a solution to your problem from YouTube:How to crack a safe wit...
Contact Homeland for the information
Hi David, This device originally shipped with a connector on the end of the power leads. Use your ohm...
be more specific,, by fix do you mean fasten ? mounting help ?
Have a tip for DSC Universal Accessories - P/N PTD1640U-CC?
My alarm keeps beeping(trouble light) at randon times, mostly around 2am and I've replaced the...
i have the code to the dsc ptd1640u, but i don't know how to set it. i need the manual. do i...
Got a low battery alarm, 12 volt battery only has 6 volts on voltage meter reading DSC transformer...
hello, we just bought a home from the bank. dsc ptd1640u unit was disconnected. Is there a manual...
My system wont go to ready. I have a 2 story home and zone 5 (my upstairs) is red and system light...
