20 Most Recent Westinghouse Electric PT-16H610S 16 in. Portable TV Questions & Answers
Can not get picture to flip
Read the setup manual more closely, the answer was very vague and a person has to pay close attention to the pictures. Found one picture that showed the menu with "flip" displayed on it.
11/20/2009 7:00:10 AM • Westinghouse... • Answered on Nov 20, 2009
OBTENER CODIGO DE ACTIVACION DE TV. WESTINGHOSE
6240y11502755
6/18/2021 5:27:02 PM • Televison &... • Answered on Jun 18, 2021
0answers
Westinghouse 32h590: I put in a dvd and it says
If 'no Disc' display is there, surely the laser pickup unit or its loading mechanism will have the fault. Check it.
8/29/2013 1:26:30 PM • Westinghouse... • Answered on Aug 29, 2013
Fuse location
There is and normally it is located inside the power supply board, where the power cord goes in. But, watch out for hazardous high voltage even if the power plug is removed.
8/6/2012 3:27:51 PM • Westinghouse... • Answered on Aug 06, 2012
During a lightning storm Westinghouse 26
Change the input to some other you are sure works. Then if the problem persists, this might need attention by a qualified service technician.
7/25/2012 5:54:01 AM • Westinghouse... • Answered on Jul 25, 2012
Will not turn on
I see so many here with no sound/nopicture issues:ISSUES: 1. IF sound main fuse/s are good.2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.4. Be safe and if you do not know what you are doing don't open the set.Answers to issues:1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.4. Safety first--no TV set is worth getting injured or even killed over.If set isopened at least look for puffed up and bad caps like in this photo5_21_2012_3_22_12_am.jpg5_21_2012_3_22_29_am.jpg
5/21/2012 3:22:41 AM • Westinghouse... • Answered on May 21, 2012
Tv has no picture only sound
the inverter is the usual cause of that issue, some westinghouse models have the inverter combined with the power board. You can get the replacement board and free tech assistance from www.tvrepairworld.com
5/17/2012 11:05:23 AM • Westinghouse... • Answered on May 17, 2012
Cant get sound to work
Let verify first to narrow down to where the problem can be. First, make sure the MUTE or SAP function is not activated, then check the on screen sound set up menu to make sure the speakers are not set to OFF. If the setting is OK, then attach the powered PC speakers to the Audio Line out RCA jacks (Red and White) to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. Please post back what you find.
Parts: www.shopjimmy.com http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guideFailed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
1/4/2011 11:54:25 PM • Westinghouse... • Answered on Jan 04, 2011
How to connect a hdmi
Plug your hdmi cable into the hdmi slot on the box then into your set. If your box doesn't have one then you either have to upgrade your box or use another method.
11/27/2010 12:32:16 AM • Westinghouse... • Answered on Nov 27, 2010
2012 troybiilt super pony transmission axel is trying to slide out how to fix it
The axles may have substantial amount of in/out play, 1/4 inch or more. Does the axle in question actually drive the wheel or does it freewheel?
It's a typical differential so if you get both wheels off the ground and spin one wheel, the other wheel should rotate in the opposite direction.
The axles are retained by the differential assembly (inside transmission) so if the axle is truly falling out, to fix it will require transmission be removed and opened. Probably not an economical repair unless you can DYI or replace with good used unit.
4/19/2024 9:41:16 PM • Televison &... • Answered 7 hours ago
What is the sky remote code for a cello model c20234f-led ?
Turn on your Sky Box and TV. On your Sky Remote, press the TV button. Simultaneously press the Select and Red buttons until the red LED on your remote blinks twice. Enter one of the following 3-digit remote codes for Sky TV: 2274 2169 1874 1798 1872 1873 The light on the remote should flash twice. If it blinks only once, repeat the steps with the next code. Press the Standby button on your remote. If your television turns off, press the Select button to save the setting. Turn on the TV and press TV Guide; if the TV Guide list displays on the screen, the programming was successful. Remember that there are multiple versions of Sky Remote Controls available, so ensure you have the most recent version. If you encounter any issues with the 3-digit codes, you can also try using a 4-digit code. Here's how: Repeat steps 1 to 3. Enter the 4-digit Sky remote code for your TV brand. Press the Standby button. If your TV turns off, press Select to save your settings. Check if the TV Guide displays successfully on the screen. Sky TV Remote Control Codes
4/19/2024 8:32:21 PM • Televison &... • Answered 8 hours ago
2answers
Harwa 32 Inch Led Television. How do I update my software on my Harwa 32 inch as my apps show it needs an update.
To update the software on your Harwa 32-inch TV, follow these steps: Check Other Solutions First: Before proceeding with a firmware update, ensure that you've tried other troubleshooting solutions. Sometimes issues can be resolved without updating the firmware. Gather Necessary Items: You'll need the following: A computer with an available USB port. A high-speed internet connection. A USB flash drive. Find Your TV Model Information: On your TV, navigate to the Help menu and select System Info. Write down your TV's model, revision, and firmware information. Download the Firmware Update: On your computer, visit the Insignia Products website at www.insigniaproducts.com. Click on Support & Service. Enter either NS-19D220NA16 or NS-19D220MX16 in the search box under Manual, Firmware, Drivers & Product Information. Follow the Firmware Installation Guide: Download the firmware update from the Insignia website. Copy the firmware file to a USB flash drive. Install the Update on Your TV: Plug the USB flash drive into the USB port on the side of your TV. Press the MENU button on your remote. Navigate to HELP and press ENTER. Highlight Update Firmware and press ENTER. Confirm that you want to update the TV firmware by selecting OK. Your TV will display a status screen while installing the update. Do not turn off your TV during this process. Once the update is complete, unplug the USB flash drive and press ENTER. Your TV will turn off and then back on to finalize the update. Rescan for Channels (if needed): If your channel list has been deleted, you'll need to scan for channels again. Refer to your TV's manual for instructions on how to do this. Remember: If you encounter a message saying the firmware file is incorrect, ensure you've downloaded the correct file for your specific model. If the update fails or your TV screen remains blank with a blinking red then blue power LED, turn off your TV, turn it back on, and run the upgrade again.
4/19/2024 7:23:41 PM • Televison &... • Answered 9 hours ago
Need a new remote control for iheater ih1500--how much does it cost and can you ship it to me? model IH1500 Serial IHA080939250
Sorry, we do not supply anything. I would aproach the supplier or manufacture for advice and spares availability.
4/19/2024 3:13:01 PM • Televison &... • Answered 13 hours ago
Westinghouse Electric PT-16H610S 16 in. Portable TV Logo
1 questions posted
Top Westinghouse Electric Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Westinghouse Electric Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Westinghouse Electric Televison & Video
Most Popular Question
not get picture flip
  • Televison & Video
