20 Most Recent Philips 32PFL6704D 32 in. LCD TV Questions & Answers
A bad connection on the small signal board may be the problem! Have a Tech check this connection, it may be to tight due to the heat shrink tube. Have them peel it back to reduce the strain! Should work then!
Philips... | Answered on Apr 14, 2010
First of all a standard screw will not work. You will have to visit your local hardware store and purchase a machine screw to fix the problem. In many cases you will have to use an estimated guess and gamble your time and money. The length and width of the machine screw will be found at this store. The effort is miniscule and money will be meager. Remember, do not use a standard screw!
Philips... | Answered on Dec 25, 2009
interference from flourecent lights, maybe the front panel buttons are stuck.
Philips... | Answered on Aug 31, 2009
NO, your remote control sounds like it is sending the signals to the TV. Take the batteries out or put it in a drawer to test. If it's the TV doing it itself, then it's a bad remote receiver circuit.
Philips... | Answered on Jun 30, 2009
necesito codigo de mando remoto huayu hr 878e para DVD LG
Philips... | Answered 6 hours ago
Use code search to find out. If a search through all codes stored in your Philips URC fails, try a different one.
Philips... | Answered on Jun 13, 2019
Usual instructions.
Turn on the TV.
Find the code(s) listed for your Phillips TV and shown in the instructions provided with your remote. (If you don't have the instructions, look on the remote manufacturer's website).
On the remote, press the "TV" button.
Then press and hold the "setup" button until the LED blinks twice. Then let go (you atr now in yhe setup mode.)
Now enter the one of the Phillips TV code numbers you got from the instructions (or website.) This is often a three digit or five digit code. If performed properly, the LED should blink twice indicating it has accepted the code. (If it did not blink twice, folliw these steps again.)
Now aim the remote at the TV and press power. The TV should turn off indicating its programned properly.
Try other functions on the remote, sound up and down, change channel, etc. If all work, your done. If not there are usually several different codes listed for every TV, just go back and try them all, until you find the one that works all functions.
Philips... | Answered on Jun 03, 2019
Not sure what your asking
Philips... | Answered on May 31, 2019
Google (Philips)(LP 2E AA)(manual) without parens.
Philips... | Answered on May 29, 2019
Hello Jaunius, indicate if the remote control you are commenting on, is an original replacement or if it is a universal remote control, indicates the type, brand and model, in order to find the best possible solution
I wait your answer
Greetings Franco Dosil
Hola Jaunius, indica si el control remoto del que estas comentando, es reemplazo original o si es un control remoto universal, indica el tipo, marca y modelo, para poder encontrar la mejor solucion posible
Espero tu respuesta
Saludos Franco Dosil
https://www.download.p4c.philips.com/files/h/hts3450_37/hts3450_37_dfu_aen.pdf
Philips... | Answered on May 22, 2019
The identity is printed on the IC.
Philips... | Answered on May 16, 2019
Hello Eric, you should be able to disable the energy saving of your Philips by entering the menu, then choose Picture, then select, Auto Picture and from there enter and select Energy Saving, where you can change the status and achieve greater clarity, all these steps are indicated in the user manual, page 31
I sent you the link to download the user manual
I hope my comment has served you
Hola Eric, deberias poder deshabilitar el ahorro de energia de tu Philips entrando en el menu, ahi elegir Picture, despues selecionar, Auto Picture y de ahi entrar y selecionar Energy Saving, donde puedes cambiar el estado y lograr mayor claridad, todos estos pasos estan indicados en el manual de usuario, pagina 31
Te envio el link para que descargues el manual de usuario
espero te haya servido mi comentario
https://www.download.p4c.philips.com/files/6/65pfl5602_f7/65pfl5602_f7_dfu_aen.pdf
https://www.download.p4c.philips.com/files/6/65pfl5602_f7/65pfl5602_f7_dfu_lsp.pdf https://www.download.p4c.philips.com/files/6/65pfl5602_f7/65pfl5602_f7_dfu_lsp.pdf
Philips... | Answered on May 02, 2019
Philips 32PFL6704D 32 in. LCD TV Logo
Popular Tags
10 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
tv note respond remote volume menu
  • Televison & Video
