my LG RC389H DVD/VHS won't receive AV1 signals from a set top box. Got it to display video once but...
(More)
my LG RC389H DVD/VHS won't receive AV1 signals from a set top box. Got it to display video once but no sound. Tried all combinations but no luck. Any ideas?
Hi I just bought an LG RC389H dvd/vhs combo and changed the region from region 4 to multi region...
(More)
Hi I just bought an LG RC389H dvd/vhs combo and changed the region from region 4 to multi region (region 0), however I changed some of the other options by error....should have only changed option 5. Do you have the orginal values of the other options or tell me where to get them. Thanks...any help is greatly appreciated!
i have a celestial tv what is the remote code to use to change chanels so as i can use the rc389h...
(More)
I HAVE A CELESTIAL TV WHAT IS THE REMOTE CODE TO USE TO CHANGE CHANELS SO AS I CAN USE THE RC389H RECORDER I HAVE TRIED THE NUMBERS LISTED ON PAGE SEVEN OF THE MANUAL BUT NONE WORK
I have a LG RC389H DVD player I want to watch other region DVD's but the DVD won't let me play them....
(More)
I have a LG RC389H DVD player I want to watch other region DVD's but the DVD won't let me play them. How can I decode the DVD to read all regions?
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
