20 Most Recent
LaCie 2tb Hard Drive Max Dual Dr Raid 0 & Raid 1 Capable 301838U Stora Questions & Answers
I need to know how to do a factory reset on a lacie 4Big Quadra enterprise.
- Disconnect all cables from the device.
- Press and hold the "reset" button (located on the rear panel) for about 10 seconds.
- Wait for the device to restart and initialize. This may take several minutes.
- Reconnect the cables to the device and try accessing it again.
Note: It's recommended to backup all data stored on the device before performing a factory reset, as all data will be lost during the reset process.
My LaCie external drive isn't getting power
U should test for power at the connector that goes into the lacie with a voltmeter to make sure power supply and its wire are OK. If no voltmeter then use a automobile brake or turn signal bulb to see if it has power.
Lacie n2870 driver
You need a new driver for sure, and here you can find it
driverupdate us. This tool usually keep my drivers up to date (perfectly for now)
take a look
